Subject: modbus R3-1 available
Date: Tue, 28 Jul 2020 21:12:40 +0000
Folks,
R3-1 of the Modbus module is now available.  This is from the release notes.
- Added support for the asynInt64 interface between device support and the driver.
- Added support for 22 new data types including unsigned integers, 64-bit integers, byte-swapped versions of all 32-bit and 64-bit data types, and zero-terminated strings.
  INT32_LE_BS Byte-swapped Int32 little-endian
  INT32_BE_BS Byte-swapped Int32 big-endian
  UINT32_LE Unsigned Int32 little-endian
  UINT32_BE Unsigned Int32 big-endian
  UINT32_LE_BS Byte-swapped unsigned Int32 little-endian
  UINT32_BE_BS Byte-swapped unsigned Int32 big-endian
  INT64_LE Int64 little-endian
  INT64_BE Int64 big-endian
  INT64_LE_BS Byte-swapped Int64 little-endian
  INT64_BE_BS Byte-swapped Int64 big-endian
  UINT64_LE Unsigned Int64 little-endian
  UINT64_BE Unsigned Int64 big-endian
  UINT64_LE_BS Byte-swapped unsigned Int64 little-endian
  UINT64_BE_BS Byte-swapped unsigned Int64 big-endian
  FLOAT32_LE_BS Byte-swapped Float32 little-endian
  FLOAT32_BE_BS Byte-swapped Float32 big-endian
  FLOAT64_LE_BS Byte-swapped Float64 little-endian
  FLOAT64_BE_BS Byte-swapped Float64 big-endian
  ZSTRING_HIGH Zero terminated string data. One character is stored in the high byte of each register.
  ZSTRING_LOW Zero terminated string data. One character is stored in the low byte of each register.
  ZSTRING_HIGH_LOW Zero terminated string data. Two characters are stored in each register, the first in the high byte and the second in the low byte.
  ZSTRING_LOW_HIGH Zero terminated string data. Two characters are stored in each register, the first in the low byte and the second in the high byte.
Note: For big-endian formats the _BE format is order in which an IEEE value would be stored on a big-endian machine, and _BE_BS swaps the bytes in each 16-bit word relative to IEEE specification. However, for little-endian formats the _LE format is byte-swapped within each 16-bit word compared how the IEEE value would be be stored on a little-endian machine.
The _LE_BS format is the order in which an IEEE value would be stored on a little-endian machine. This is done for backwards compatibility, because that is how _LE has always been stored in previous versions of this modbus module.
- Converted the documentation from HTML to REst, and moved to https://epics-modbus.readthedocs.io/en/latest/.
- Converted the release notes from HTML to Github Markdown and moved to https://github.com/epics-modules/modbus/blob/master/RELEASE.md.
- Improved debugging by returning the actual number of bytes transfered in read operations in the interpose interface functions.
- Fixed writing strings with absolute addressing.
- Fixed the length limit of function codes 1,2,5 and 15. It was previously allowing allowing 2015 and 1983 bits, rather than 2000 and 1968.
- Added support for specifying the maximum length of strings in the drvUser field. STRING_HIGH=17 would result in a 16 character long string (plus terminating 0 byte)
- Handle errors in drvModbusAsynConfigure.
Thanks to Krisztian Loki from ESS for the ZSTRING support and the last 4 fixes above.
Home page:
Documentation (new location):
Release notes (new location):
Cheers,
Prev: RE: How to check IOC connection Mark Rivers via Tech-talk
Next: RE: ADProsilica crashing on RHEL7 3.10.0-1127 Pearson, Matthew R. via Tech-talk
Prev: 回复: EPICS support for Linkam T96 controller in Linux. Li, Ji via Tech-talk
Next: looking for aai/waveform example David A. Slimmer via Tech-talk
