Subject: Re: EPICS Base Compilation Failed Under Cygwin gcc 9+
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Paul Chu <[email protected]>
Date: Thu, 30 Jul 2020 18:11:03 +0000
Hi Freddie,
Will that #include change need to be wrapped in some GCC or Cygwin version check? I wouldn’t want to break builds against older versions, especially since we aren’t actively testing Cygwin builds any more.
- Andrew
On Jul 30, 2020, at 12:42 PM, Paul Chu via Tech-talk <[email protected]> wrote:
Thanks Freddie,
Yes, your solution does the trick. It should probably be added to the future release.
Paul
From: Freddie Akeroyd - UKRI STFC <[email protected]>
Sent: Thursday, July 30, 2020 7:24 PM
To: Paul Chu <[email protected]>; [email protected]
Subject: RE: EPICS Base Compilation Failed Under Cygwin gcc 9+
I wonder if the definition of TCP_NODELAY has moved location in gcc 9.0.*  - if you add:
    #include <netinet/tcp.h>
To the file does that help? If so, then    modules/libcom/src/osi/os/cygwin32/osdSock.h    is probably a better place for it to be more permanently added.
Freddie
From: Tech-talk <[email protected]> On Behalf Of Paul Chu via Tech-talk
Sent: 30 July 2020 08:10
To: '[email protected]' <[email protected]>
Subject: EPICS Base Compilation Failed Under Cygwin gcc 9+
The EPICS Base is broken for Cygwin under gcc 9.0.* The error message seems pointing to “TCP_NODELAY” not declared. I tried for several Base 3.15.*, 3.14.*, and 7.*, and all got the same error messages (see below). If using gcc 7.4.*, all versions can compile without any issue.  Does anybody experience the same issue?
g++  -D_POSIX_THREADS -D_POSIX_TIMERS           -DUNIX  -DCYGWIN32     -O3 -g   -Wall      -m64   -DEPICS_BUILD_DLL -DEPICS_CALL_DLL   -I. -I../O.Common -I. -I. -I.. -I../../../../src/ca/client/test -I../../../../include/compiler/gcc -I../../../../include/os/cygwin32 -I../../../../include         -o tcpiiu.obj -c ../tcpiiu.cpp
In file included from ../localHostName.h:32,
                 from ../tcpiiu.cpp:32:
../../../../include/epicsSingleton.h:164:15: warning: ‘void* SingletonUntyped::pInstance() const’ redeclared without dllimport attribute after being referenced with dll linkage
  164 | inline void * SingletonUntyped :: pInstance () const
../tcpiiu.cpp: In constructor ‘tcpiiu::tcpiiu(cac&, epicsMutex&, epicsMutex&, cacContextNotify&, double, epicsTimerQueue&, const osiSockAddr&, comBufMemoryManager&, unsigned int, ipAddrToAsciiEngine&, const priLev&, SearchDestTCP*)’:
../tcpiiu.cpp:728:56: error: ‘TCP_NODELAY’ was not declared in this scope
  728 |     int status = setsockopt ( this->sock, IPPROTO_TCP, TCP_NODELAY,
make[3]: *** [../../../../configure/RULES_BUILD:240: tcpiiu.obj] Error 1
make[3]: Leaving directory '/cygdrive/c/epics/base-3.15.7/src/ca/client/O.CYGWIN-X86_64'
make[2]: *** [../../../configure/RULES_ARCHS:58: install.CYGWIN-X86_64] Error 2
make[2]: Leaving directory '/cygdrive/c/epics/base-3.15.7/src/ca/client'
make[1]: *** [../configure/RULES_DIRS:84: ca/client.install] Error 2
make[1]: Leaving directory '/cygdrive/c/epics/base-3.15.7/src'
make: *** [configure/RULES_DIRS:84: src.install] Error 2
Paul
Paul Chu
Head of Accelerator Division
Nanjing Proton Source
Nanjing University, Nanjing, China
<image001.png>
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Complexity comes for free, simplicity you have to work for.
RE: EPICS Base Compilation Failed Under Cygwin gcc 9+ Freddie Akeroyd - UKRI STFC via Tech-talk
EPICS Base Compilation Failed Under Cygwin gcc 9+ Paul Chu via Tech-talk
RE: EPICS Base Compilation Failed Under Cygwin gcc 9+ Paul Chu via Tech-talk
Prev: RE: EPICS Base Compilation Failed Under Cygwin gcc 9+ Paul Chu via Tech-talk
Next: Attocube IDS3010 Randall Cayford via Tech-talk
Next: RE: EPICS Base Compilation Failed Under Cygwin gcc 9+ Freddie Akeroyd - UKRI STFC via Tech-talk
