1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
Subject: Re: MiniPIX TPX3 detector
From: "Wang Xiaoqiang \(PSI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "Gofron, Kazimierz" <kgofron at bnl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 3 Aug 2020 19:42:58 +0000
I put up the code here.
https://github.com/paulscherrerinstitute/pixet_epics
Best
Xiaoqiang
> On 3 Aug 2020, at 19:33, Gofron, Kazimierz <kgofron at bnl.gov> wrote:
> Hi Xiaoqiang,
> Please upload the script, since this might be the quickest way to get this compact detector running.
> Kazimierz
> From: Wang Xiaoqiang (PSI) <xiaoqiang.wang at psi.ch>
> Sent: Monday, August 3, 2020 12:06 PM
> To: Gofron, Kazimierz <kgofron at bnl.gov>
> Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
> Hi,
> This type of detector is controlled via their Pixet program,
> which has an embedded Python interpreter. Then inside the program,
> Python scripts can be loaded to call its API functions.
> We found it mostly easy to run a PCASpy server. In case you are
> interested in this approach, I can upload the script.
> Best
> Xiaoqiang
> > On 3 Aug 2020, at 17:49, Gofron, Kazimierz via Tech-talk <tech-talk at aps.anl.gov> wrote:
> > Hi,
> > Has anyone created EPICS support for MiniPIX TPX3 detector (with USB2 interface) in Linux?  Thanks.
> > https://urldefense.com/v3/__https://advacam.com/minipix__;!!P4SdNyxKAPE!TmgJH5XbuSkGliqnE9pGcGUxgo6g9M73xrgPxbvc0g1DpoVtGo3eylabZIEpzsCw$
> > Regards,
> > Kazimierz
Re: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Re: MiniPIX TPX3 detector Wang Xiaoqiang (PSI) via Tech-talk
Prev: Re: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Next: Re: MiniPIX TPX3 detector Gofron, Kazimierz via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024
ANJ, 03 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
