1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: ADAravis: arvFeature.cpp
From: Jure Varlec via Tech-talk <tech-talk at aps.anl.gov>
To: John Dobbins <john.dobbins at cornell.edu>
Cc: tech-talk at aps.anl.gov
Date: Tue, 11 Aug 2020 14:27:35 +0200
Hi John,
Aravis is changing its API and ADAravis is being updated to match. You
will need Aravis 0.7.x to get the new API.
Best
Jure
John Dobbins via Tech-talk <tech-talk at aps.anl.gov> writes:
> All,
> In attempting to build ADAravis ( Aravis package 0.6.3  , base-7.0.3.1, areaDetector-master)  I encountered a number of errors along the lines
> make[5]: Entering directory `/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADAravis/aravisApp/src/O.linux-x86_64'
> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE           -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall      -mtune=generic      -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include      -I/nfs/bbl/online/epics/b7/synApps/support/asyn-R4-40/include     -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include/os/Linux -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADSupport/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADCore/include -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/compiler/gcc -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include/os/Linux -I/nfs/bbl/online/epics/b7/base-7.0.3.1/include   -I/nfs/bbl/online/epics/b7/synApps/support/areaDetector-master/ADGenICam/include     -I/usr/include/glib-2.0 -I/usr/lib64/glib-2.0/include -I/usr/local/include/aravis-0.8    -c ../arvFeature.cpp
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readInteger()\u2019:
> ../arvFeature.cpp:42:84: error: too many arguments to function \u2018gint64 arv_device_get_integer_feature_value(ArvDevice*, const char*)\u2019
>      return arv_device_get_integer_feature_value(mDevice, mFeatureName.c_str(), NULL);
> In file included from /usr/include/arvinterface.h:31:0,
>                  from /usr/include/arv.h:66,
>                  from ../arvFeature.h:8,
>                  from ../arvFeature.cpp:5:
> /usr/include/arvdevice.h:115:9: note: declared here
>  gint64  arv_device_get_integer_feature_value (ArvDevice *device, const char *feature);
> ../arvFeature.cpp: In member function \u2018virtual epicsInt64 arvFeature::readIntegerMin()\u2019:
> ../arvFeature.cpp:47:90: error: too many arguments to function \u2018void arv_device_get_integer_feature_bounds(ArvDevice*, const char*, gint64*, gint64*)\u2019
>      arv_device_get_integer_feature_bounds(mDevice, mFeatureName.c_str(), &min, &max, NULL);
> /usr/include/arvdevice.h:116:8: note: declared here
>  void   arv_device_get_integer_feature_bounds  (ArvDevice *device, const char *feature, ....
> Any help is appreciated!
> John Dobbins
> Research Support Specialist
> Cornell High Energy Synchrotron Source
> Cornell University
> www.chess.cornell.edu<http://www.chess.cornell.edu>
> Maybe it's all part of a great big ineffable plan. - Neil Gaiman, _Good Omens_
Re: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
ADAravis: arvFeature.cpp John Dobbins via Tech-talk
Prev: ADAravis: arvFeature.cpp John Dobbins via Tech-talk
Next: Re: ADAravis: arvFeature.cpp Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 11 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
