Subject: Re: Building with debug information
From: Ben Franksen via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 13 Aug 2020 14:42:32 +0200
Am 13.08.20 um 14:01 schrieb Ralph Lange via Tech-talk:
> On Thu, 13 Aug 2020 at 13:23, Ben Franksen via Tech-talk <
> [email protected]> wrote:
>> But what I want is to tweak the configuration in EPICS base so
>> that linux-x86_64 is treated as if it were linux-x86_64-debug, so
>> that building with debug information is the default. What would be
>> the simplest way to achieve that?
> For most architectures, setting HOST_OPT or CROSS_OPT to NO should
> be enough. (Details to be found in the Base configuration files for
> the -debug architectures.)
> Can be done in any configuration (preferably CONFIG_SITE type),
> Makefile, command line...
Thanks, but I don't want to disable optimizations by default!
I found that I can get what I want if I copy the lines
OPT_CFLAGS_YES += -g
OPT_CXXFLAGS_YES += -g
from our CONFIG_SITE.Common.linux-x86_64 to
CONFIG_SITE.linux-x86_64.linux-x86_64.
And then I remembered that I have complained about this before and it
was acknowledged that the inclusion order is wrong here, which is why
adding these lines to CONFIG_SITE.Common.linux-x86_64 didn't have the
desired effect. This might have been fixed or not (I am working with
3.15.6 ATM).
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Building with debug information Ben Franksen via Tech-talk
Re: Building with debug information Ralph Lange via Tech-talk
Prev: Re: Building with debug information Ralph Lange via Tech-talk
Next: Re: MVME-162 CPU Boards Amit Chauhan via Tech-talk
Next: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
