That folder contains the .jar files for CA and PVA.
Did you do “Plugins/Compile and run” to compile the plugins once?
Sent from my iPhone
On Aug 13, 2020, at 6:11 PM, Gofron, Kazimierz <kgofron at bnl.gov> wrote:
No, I only copied the EPICS_areaDetector folder to the /usr/share/imagej/plugins.
Sent: Thursday, August 13, 2020 6:05 PM
To: Gofron, Kazimierz <kgofron at bnl.gov>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
pvget does not need to be available to use ImageJ.
Did you install all of the latest .jar files from ADViewers as well?
Sent from my iPhone
On Aug 13, 2020, at 5:00 PM, Gofron, Kazimierz <kgofron at bnl.gov> wrote:
pvget does access the Pva data, though it is not defined in my environment when I start the imagej.
> pvget XF:10IDA-BI{WBS-Cam:1}Pva1:Image
XF:10IDA-BI{WBS-Cam:1}Pva1:Image epics:nt/NTNDArray:1.0
union value
ubyte[] [6,5,5,6,6,6,4,5,5,5,4,5,5,5,5,5,4,6,5,5,5,6,6,6,6,6,5,5,4,5,5,5,6,4,5,5,6,5,4,5,5,6,6,6,4,6,6,5,5,5,5,5,6,6,5,5,5,5,6,6,6,5,5,6,5,6,6,5,5,5,6,5,5,5,6,6,6,5,6,6,5,4,4,5,6,6,5,5,6,5,5,5,5,5,6,5,6,5,6,5,7,5,5,5,6,5,6,4,5,6,4,6,5,5,5,6,6,6,5,6,7,6,5,6,7,6,5,5,6,5,6,6,6,5,6,6,6,6,7,6,6,6,6,6,6,5,4,6,6,6,6,6,6,5,5,5,5,6,6,5,6,6,6,5,6,5,6,5,5,7,6,5,6,6,6,6,6,7,5,5,5,7,6,6,6,6,6,5,5,6,6,6,6,6,6,5,5,6,5,6,5,6,6,6,6,5,5,6,6,5,6,6,6,6,6,5,8,6,5,6,6,7,6,7,5,6,6,6,6,6,6,6,5,6,6,6,6,7,7,6,7,6,7,6,6,6,6,6,6,6,7,5,7,6,6,6,6,6,7,8,7,6,7,5,6,5,7,5,6,6,7,6,6,6,7,6,6,7,6,6,6,6,5,5,6,7,6,6,7,6,7,6,7,6,7,6,6,6,7,8,5,7,7,6,5,6,7,6,7,7,6,8,7,6,6,6,7,6,7,6,7,8,6,6,7,7,7,6,6,6,8,7,6,6,7,7,8,8,6,7,7,6,7,7,6,6,6,8,7,6,6,7,7,7,7,7,7,8,7,7,6,7,6,7,7,7,7,6,7,7,6,7,8,6,7,7,7,7,7,7,7,7,7,8,8,7,6,7,7,8,8,7,7,6,7,7,8,7,8,7,6,7,7,6,7,7,6,7,8,7,9,7,6,7,8,6,8,7,8,8,8,7,7,7,8,8,8,7,7,6,8,7,
display_t display
double limitLow 0
double limitHigh 0
string description
string format
string units
Sent: Thursday, August 13, 2020 5:49 PM
Subject: RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
The first thing to test is to see if it is a problem with the Java PVA client used in ImageJ. Does pvget work to read the NTNDArray on the same computer that is running ImageJ?
Sent: Thursday, August 13, 2020 4:41 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Hi Mark,
The 10.10.2.4, and 10.10.1.3 are ioc server interfaces where camera ioc is running.
kgofron@xf10idd-ioc1:~$ /sbin/ifconfig
eth2 Link encap:Ethernet HWaddr 40:f2:e9:f1:5e:5c
inet addr:10.10.2.4 Bcast:10.10.3.255 Mask:255.255.254.0
eth5 Link encap:Ethernet HWaddr 40:f2:e9:18:04:d4
inet addr:10.10.0.2 Bcast:10.10.0.255 Mask:255.255.255.0
inet6 addr: fe80::42f2:e9ff:fe18:4d4/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:9000 Metric:1
RX packets:13366912123 errors:0 dropped:15 overruns:2093 frame:0
TX packets:58127067732 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:1107045874580 (1.0 TiB) TX bytes:138303991851304 (125.7 TiB)
eth6 Link encap:Ethernet HWaddr 40:f2:e9:18:04:d0
inet addr:10.10.1.3 Bcast:10.10.1.255 Mask:255.255.255.0
inet6 addr: fe80::42f2:e9ff:fe18:4d0/64 Scope:Link
RX packets:10991622206 errors:0 dropped:0 overruns:0 frame:0
TX packets:3222525720 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:76509026723747 (69.5 TiB) TX bytes:24100596376483 (21.9 TiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
I have never seen these errors either with old-old version of PvA plugin that runs on other workstations.
K
From: Mark Rivers <rivers at cars.uchicago.edu<mailto:rivers at cars.uchicago.edu>>
Sent: Thursday, August 13, 2020 5:33 PM
To: Gofron, Kazimierz <kgofron at bnl.gov<mailto:kgofron at bnl.gov>>
Cc: tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov> <tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>>
Hi Kaz,
> Camera Manta G-125B
> S/N: xxxxx
> Firmware: 00.01.44.18241
> SDK: 1.26
> Driver: 2.5.0
> ADCore: 3.5.0
None of that should matter.
> kgofron@xf10id-ws1:~$ export EPICS_CA_MAX_ARRAY_BYTES=6000000
That is not relevant to pvAccess.
> Aug 13, 2020 4:59:34 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
> SEVERE: Failed to create transport for: /10.10.0.2:48464
> org.epics.pvaccess.impl.remote.ConnectionException: Failed to connect to '/10.10.0.2:48464'.
> SEVERE: Failed to create transport for: /10.10.1.3:48464
> org.epics.pvaccess.impl.remote.ConnectionException: Failed to connect to '/10.10.1.3:48464'.
I have never seen errors like those, so I don’t know what could be wrong.
> My EPICS VLAN interfaces are on 10.10.0.x, and interfaces 10.10.1.y are for direct access to webcams.
What is at IP addresses 10.10.0.2 and 10.10.1.3?
From: Tech-talk <tech-talk-bounces at aps.anl.gov<mailto:tech-talk-bounces at aps.anl.gov>> On Behalf Of Gofron, Kazimierz via Tech-talk
Sent: Thursday, August 13, 2020 4:17 PM
To: tech-talk at aps.anl.gov<mailto:tech-talk at aps.anl.gov>
Subject: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers
Camera Manta G-125B
S/N: xxxxx
SDK: 1.26
Driver: 2.5.0
ADCore: 3.5.0
OS (client where imagej is running): Debian 10
OS (EPICS ioc server): Debian 7
imagej debian version:
kgofron@xf10id-ws1:~$ dpkg -l | grep imagej
ii imagej 1.52j-1 all Image processing program with a focus on microscopy images
I just cloned the master version of imagej viewers, and 'EPICS_AD Viewer' CA version works fine, but the 'EPICS_NTNDA_VIEWER' PVA version does not connect. Am I missing something?
In the same time CSS opi displays PvA images correctly.
kgofron@xf10id-ws1:~$ imagej
Open other images in this ImageJ panel as follows:
imagej -p 1 <image1> [<image2> ... <imageN>]
at org.epics.pvaccess.client.impl.remote.tcp.BlockingTCPConnector.connect(BlockingTCPConnector.java:163)
at org.epics.pvaccess.client.impl.remote.ClientContextImpl.getTransport(ClientContextImpl.java:1125)
at org.epics.pvaccess.client.impl.remote.ChannelImpl.searchResponse(ChannelImpl.java:453)
at org.epics.pvaccess.client.impl.remote.search.SimpleChannelSearchManagerImpl.searchResponse(SimpleChannelSearchManagerImpl.java:384)
at org.epics.pvaccess.client.impl.remote.handlers.SearchResponseHandler.handleResponse(SearchResponseHandler.java:94)
at org.epics.pvaccess.client.impl.remote.ClientResponseHandler.handleResponse(ClientResponseHandler.java:108)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport.processBuffer(BlockingUDPTransport.java:336)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport.processRead(BlockingUDPTransport.java:263)
at org.epics.pvaccess.impl.remote.udp.BlockingUDPTransport$1.run(BlockingUDPTransport.java:159)
at java.base/java.lang.Thread.run(Thread.java:834)
Caused by: java.lang.NoClassDefFoundError: org/omg/CORBA/ShortHolder
at org.epics.pvaccess.impl.remote.IntrospectionRegistry.<init>(IntrospectionRegistry.java:77)
at org.epics.pvaccess.impl.remote.tcp.BlockingTCPTransport.<init>(BlockingTCPTransport.java:64)
at org.epics.pvaccess.client.impl.remote.tcp.BlockingClientTCPTransport.<init>(BlockingClientTCPTransport.java:96)
at org.epics.pvaccess.client.impl.remote.ClientContextImpl$1.create(ClientContextImpl.java:417)
at org.epics.pvaccess.client.impl.remote.tcp.BlockingTCPConnector.connect(BlockingTCPConnector.java:137)
... 9 more
Caused by: java.lang.ClassNotFoundException: org.omg.CORBA.ShortHolder
at java.base/java.net.URLClassLoader.findClass(URLClassLoader.java:471)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:589)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 14 more
... 9 more
Aug 13, 2020 4:59:35 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
... 9 more
... 9 more
Aug 13, 2020 4:59:36 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:38 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:39 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:42 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:49 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
... 9 more
Aug 13, 2020 4:59:50 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
Aug 13, 2020 4:59:51 PM org.epics.pvaccess.client.impl.remote.ClientContextImpl getTransport
... 9 more
- Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
- ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Gofron, Kazimierz via Tech-talk
- RE: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
- Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
cannot read epics archive(d) data with CS-studio astrid morreale via Tech-talk
<2020>
2025
<2020>
2025
