1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Question about static linking in the EPICS build system
From: "Wlodek, Jakub via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 14 Aug 2020 20:13:20 +0000
Hi all,
I have been working for some time on allowing fully static linking of an areaDetector driver I wrote some time ago:
At first, I used $(PROD_NAME)_SYS_LIBS to link to the support library I used for communicating with the device, but
I would like to change this to $(PROD_NAME)_LIBS since it would be my understanding that this would mean that the driver application
could be built entirely statically, making it more portable since then the support library wouldn't have to be installed and in the system path
during runtime.
When using SYS_LIBS, the driver library and IOC application build without issue, however, when I change to just LIBS, the library still
compiles OK, but I get many undefined reference errors when compiling the App:
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_get_scanning_mode':
ctrl-gen.c:(.text+0x5b): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_set_scanning_mode':
ctrl-gen.c:(.text+0xea): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_get_ae_mode':
ctrl-gen.c:(.text+0x17b): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_set_ae_mode':
ctrl-gen.c:(.text+0x20a): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o): In function `uvc_get_ae_priority':
ctrl-gen.c:(.text+0x29b): undefined reference to `libusb_control_transfer'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(ctrl-gen.c.o):ctrl-gen.c:(.text+0x32a): more undefined references to `libusb_control_transfer' follow
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_free_device_info':
device.c:(.text+0x4c6): undefined reference to `libusb_free_config_descriptor'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_get_device_descriptor':
device.c:(.text+0x58d): undefined reference to `libusb_get_device_descriptor'
device.c:(.text+0x5f1): undefined reference to `libusb_open'
device.c:(.text+0x618): undefined reference to `libusb_get_string_descriptor_ascii'
device.c:(.text+0x640): undefined reference to `libusb_get_string_descriptor_ascii'
device.c:(.text+0x668): undefined reference to `libusb_get_string_descriptor_ascii'
device.c:(.text+0x683): undefined reference to `libusb_close'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_get_device_list':
device.c:(.text+0x711): undefined reference to `libusb_get_device_list'
device.c:(.text+0x769): undefined reference to `libusb_get_config_descriptor'
device.c:(.text+0x77d): undefined reference to `libusb_get_device_descriptor'
device.c:(.text+0x81c): undefined reference to `libusb_free_config_descriptor'
device.c:(.text+0x83c): undefined reference to `libusb_free_device_list'
device.c:(.text+0x969): undefined reference to `libusb_free_config_descriptor'
device.c:(.text+0x996): undefined reference to `libusb_ref_device'
/epics/src/support/areaDetector/ADUVC/lib/linux-x86_64/libuvc.a(device.c.o): In function `uvc_find_device':
device.c:(.text+0xac2): undefined reference to `libusb_get_device_descriptor'
device.c:(.text+0xb09): undefined reference to `libusb_unref_device'
device.c:(.text+0xb51): undefined reference to `libusb_open
The support library in use depends on libusb and libjpeg, both of which are found during the cmake build for said library. It is built both statically and dynamically.
I ran nm on the static library, and I did see the libusb functrions listed:
                 U _GLOBAL_OFFSET_TABLE_
0000000000000000 d isight_tag.6062
                 U libusb_alloc_transfer
                 U libusb_cancel_transfer
                 U libusb_control_transfer
                 U libusb_free_ss_endpoint_companion_descriptor
                 U libusb_free_transfer
                 U libusb_get_ss_endpoint_companion_descriptor
                 U libusb_set_interface_alt_setting
                 U libusb_submit_transfer
It is clear to me that this is some error I have in the linking process/configuration, but I can't seem to figure out what
specifically it could be. I have tried adding libusb to the LIBS for the ioc application (copying the statically compiled library to
ADUVC/lib/linux-x86_64), but this gave me the same error, and the same when I added libusb to SYS_LIBS.
I have had similar issues when trying to get a static build of OpenCV to link against an areaDetector application -
it works fine when building the intermediate libraries (plugins, driver lib), but when building the final IOC application I got undefined reference errors.
If anyone has an idea on what I should change, it would be much appreciated.
Thanks!
Jakub Wlodek
Re: Question about static linking in the EPICS build system Mark Rivers via Tech-talk
Prev: Re: ADViewers: EPICS_NTNDA_VIEWER' does not connect - ADViewers Mark Rivers via Tech-talk
Next: accepting channel name drops in Qt from MEDM Thomas, Patrick via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: Calling external program and read return value into record Johnson, Andrew N. via Tech-talk
Next: Re: Question about static linking in the EPICS build system Mark Rivers via Tech-talk
ANJ, 14 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
