Hi Patrick,
(Another Andrew here). I don’t know very much about this but drag-and-drop from MEDM was an issue a long time ago, I think Motif’s D&D protocol may be somewhat strange, but to help with that APS wrote another EPICS extension called namecapture for
use with other X11 clipboard programs. If you’re currently building MEDM this might be helpful, although as I said I don’t really understand the issues properly myself.
- Andrew
On Aug 20, 2020, at 1:59 PM, Thomas, Patrick via Tech-talk < tech-talk at aps.anl.gov> wrote:
Hi Andrew,
Thank you. Do you mind if I ask how you were able to get the copy and paste to work?
Patrick
Hi Patrick,
I think medm must use a different drag-drop mechanism from that used by Qt.
The best I could do was use middle-click on medm to copy the PV name into the
copy-paste buffer, and then paste it to a Qt widget.
Regards
Andrew
I was wondering if anyone has been able to get a Qt widget to accept channel name drops from MEDM?
Complexity comes for free, simplicity you have to work for.
- RE: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL] STARRITT, Andrew via Tech-talk
- Re: accepting channel name drops in Qt from MEDM [SEC=UNOFFICIAL] Thomas, Patrick via Tech-talk
Suggestion on LVDT? Shen, Guobao via Tech-talk
<2020>
2025
websocket connection via Streamdevice Hetz, Benjamin via Tech-talk
<2020>
2025
ANJ, 20 Aug 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
