1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: installing synApps on Ubuntu
From: Mark Rivers via Tech-talk <tech-talk at aps.anl.gov>
To: Randall Cayford <rcayford at lbl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 20 Aug 2020 20:02:12 +0000
>  The dxp module won’t compile over some problem with finding functions in what appears to be libusb.
There are 2 usb libraries, libusb-1.0 and the older libusb-0.x. You need the older one installed for dxp.
Sent from my iPhone
> On Aug 20, 2020, at 12:53 PM, Randall Cayford via Tech-talk <tech-talk at aps.anl.gov> wrote:
> I found the problem.  The defaults for tar on centos 7 and Ubuntu 18 are different.  On centos, untaring synApps assigns the user who untars.  On Ubuntu (at least with the parameters I used) the assigned user appears to be the uid and gid of whoever created it.  I don’t know why compiling as root has a problem with this but the depends.pl script hangs in that case.  chown fixed the problem.
> I have mostly successfully compiled synApps on Ubuntu now.  The dxp module won’t compile over some problem with finding functions in what appears to be libusb.  That one I haven’t solved.
> Thanks.
> Randall
>> On Aug 20, 2020, at 7:39 AM, Engbretson, Mark S. <engbretson at anl.gov> wrote:
>> On the module that it is stuck on, do a make distclean, and then start a recompile there.  I have seen the same situation where something goes screwy with a time stamp so thinks that something has to be recompiled when it doesn't.
>> -----Original Message-----
>> From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Michael Davidsaver via Tech-talk
>> Sent: Tuesday, August 18, 2020 8:43 PM
>> Cc: tech-talk at aps.anl.gov
>>> On 8/18/20 2:45 PM, Randall Cayford via Tech-talk wrote:
>>> We must be missing something obvious but synApps won’t install on Ubuntu for us.  The problem step is make release hangs forever.  Some problem with perl but we don’t know what.
>>> Steps:
>>> install ubuntu 18 LTS
>>> Install EPICS7
>>> Unzip the synApps (6_1) tar file and edit config files run “make
>>> release”
>>> Wait forever….
>> What, if anything, is printed while you are waiting?
>>> Exact same procedure installs fine on Centos 7.  Since there isn’t a lot of chatter about this, it seems like we’re missing a step somewhere.  Anyone know what we need to do?
>> I occasionally have builds get stuck in infinite loops, repeating the same set of steps until I interrupt.
>> So far this hasn't happen often or predictably enough to do much troubleshooting.
installing synApps on Ubuntu Randall Cayford via Tech-talk
Re: installing synApps on Ubuntu Michael Davidsaver via Tech-talk
Re: installing synApps on Ubuntu Randall Cayford via Tech-talk
Prev: Suggestion on LVDT? Shen, Guobao via Tech-talk
Next: Re: Suggestion on LVDT? Makarov, Oleg A. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: installing synApps on Ubuntu Johnson, Andrew N. via Tech-talk
Next: ADEiger 1.8 Miceli, Antonino via Tech-talk
ANJ, 20 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
