1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: error trying to compile ca-gateway on macOS mojave
From: Vivian O'Dell via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Thu, 27 Aug 2020 18:23:41 +0000
I get the following error message:
mac-130048:gateway2_0_6_0 odell$ make
/Library/Developer/CommandLineTools/usr/bin/make -C ./configure install
/Library/Developer/CommandLineTools/usr/bin/make -C O.darwin-x86 -f ../Makefile TOP=../..
T_A=darwin-x86 install
perl -CSD /Users/odell/base-3.15.7/bin/darwin-x86/convertRelease.pl checkRelease
/Library/Developer/CommandLineTools/usr/bin/make -C ./src install
c++ -DUNIX -Ddarwin -O3 -g -Wall -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -arch x86_64 -fno-common -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/clang -I../../include/os/Darwin -I../../include -I/Users/odell/base-3.15.7/include/compiler/clang -I/Users/odell/base-3.15.7/include/os/Darwin -I/Users/odell/base-3.15.7/include -I/Users/odell/base-3.15.7/src/cas/generic -I/Users/odell/base-3.15.7/src/ca/legacy/pcas/generic -c ../gatePv.cc
In file included from ../gatePv.cc:71:
../gateAs.h:138:27: error: field has incomplete type 'struct re_pattern_buffer'
struct re_pattern_buffer pat_buff;
../gateAs.h:138:9: note: forward declaration of 're_pattern_buffer'
../gateAs.h:139:22: error: field has incomplete type 'struct re_registers'
struct re_registers regs;
../gateAs.h:139:9: note: forward declaration of 're_registers'
2 errors generated.
make[2]: *** [gatePv.o] Error 1
make[1]: *** [install.darwin-x86] Error 2
make: *** [src.install] Error 2
I get the same error message with more recent versions of ca-gateway as well. I'm using EPICS 3.15.7.
This version of gateway compiles fine on the beagle bone. Is there an obvious fix for this?
Re: error trying to compile ca-gateway on macOS mojave Johnson, Andrew N. via Tech-talk
Prev: Re: Receiving duplicate monitor values using CA PV Gateway Ralph Lange via Tech-talk
Next: Re: error trying to compile ca-gateway on macOS mojave Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 27 Aug 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
