1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: PTP hardware timestamps in EPICS facilities
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "Frank, William (STFC,RAL,ISIS)" <william.frank at stfc.ac.uk>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 30 Aug 2020 22:28:37 -0700
I can't speak for the applicability of PTP.  I can speak for the MRF event
timing hardware, and event timing in general, which are in wide use at
accelerator facilities (including DLS).  These systems provide both trigger
distribution and timestamping over a dedicated fiber optic network.
http://mrf.fi/
An EPICS driver (which I'm involved with)
http://epics.sourceforge.net/mrfioc2/
On 8/28/20 7:24 AM, Frank, William (STFC, RAL, ISIS) via Tech-talk wrote:
> Hi,
> I’m working on a replacement distributed DAQ system for our accelerators at the ISIS Neutron and Muon Source in the UK.
> As part of this we are investigating hardware time-stamping (on acquisition trigger) in order to correlate the stored data from different systems offline. This has led us to look at PTPv2 (IEEE-1588-2008) and PTPv2.1 (IEEE-1588-2019), better known as White Rabbit.
> Our accelerator control system is built on Vsystem from Vista Control Systems but we are in the very early stages of evaluating a potential migration to EPICS.
> My question is whether anyone here knows of any other facilities (existing or planned) that use PTP hardware timestamping within an EPICS facility? An initial review has led me to ITER (PTPv2 and EPICS), the work done by Seven Solutions on the Low Level RF controller for IFMIF/EVED (White Rabbit and EPICS) and D-TACQ Solutions who provide White Rabbit enabled DAQ boards with EPICS on-board. If anyone is aware of any others then please let me know as we are interested in future discussion and/or collaboration opportunities.
> Thanks,
> Will
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
RE: PTP hardware timestamps in EPICS facilities Frank, William (STFC, RAL, ISIS) via Tech-talk
Prev: PTP hardware timestamps in EPICS facilities Frank, William (STFC, RAL, ISIS) via Tech-talk
Next: Re: PTP hardware timestamps in EPICS facilities Lucas Russo via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Next: RE: PTP hardware timestamps in EPICS facilities Frank, William (STFC, RAL, ISIS) via Tech-talk
ANJ, 03 Sep 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
