1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: autosave for V4 PVA record
From: Sandeep Kumar Malu - UKRI STFC via Tech-talk <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Wed, 2 Sep 2020 15:28:38 +0000
Hi All,
I am following the same procedure to do the autosave for V3 db records & V4 PVA records. My IOC looks similar to  https://github.com/epics-base/exampleCPP/tree/master/database.  Autosave lines in st.cmd are
set_requestfile_path("$(TOP)/autoSaverestore")
set_savefile_path("$(TOP)/autoSaverestore")
set_pass0_restoreFile("autosaverecord.sav")
set_pass1_restoreFile("autosaverecord.sav")
cd "${TOP}/iocBoot/${IOC}"
iocInit
create_monitor_set("autosaverecord.req", 5)
The output on epics console has error:
save_restore: connect failed for channel 'PVA_Double_Test'
autosaverecord.req” file has both V3 & V4 record & has contents
PVA_Double_Test
CA_Double_Test
autosaverecord.sav file after autosave gives below contents
# autosave R5.3 Automatically generated - DO NOT MODIFY - 200902-193433
! 1 channel(s) not connected - or not all gets were successful
#PVA_Double_Test Search Issued
CA_Double_Test 8.9
<END>
So, the bottom line is autosave works for V3 type record but fails to do for V4 type PVA record. Any suggestion would be highly appreciated.
Many Thanks
Sandeep
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Prev: Re: change MACRO with text-entry value in CSS Phoebus Kacper Kłys via Tech-talk
Next: RE: Support for Watlow EZ-zone PM controller Taufer, Gary via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: RE: Support for Watlow EZ-zone PM controller Taufer, Gary via Tech-talk
Next: areaDetctor NDPluginProcess Background Saving John Dobbins via Tech-talk
ANJ, 02 Sep 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
