1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: RE: Re: Problem with installing epics base on Jetson nano
To: "Johnson, Andrew N." <anj at anl.gov>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 17 Sep 2020 09:57:45 +0900 (KST)
Hi Andrew,
Build finished without any obvious error messages but there were some error messages in the built-in unit tests by typing 'make -s runtests'.
The attached is log file captured in the process.
- Dong Ho, SHIN
-----Original Message-----
To: "신동호" <dhshin at etri.re.kr>;
Cc: "EPICS tech-talk" <tech-talk at aps.anl.gov>;
Sent: 2020-09-16 (수) 15:15:07 (UTC+09:00)
Subject: Re: Problem with installing epics base on Jetson nano
Hi Dong Ho,
On Sep 15, 2020, at 7:13 PM, 신동호 <dhshin at etri.re.kr> wrote:
Hi, Andrew
I send the output from command perl -V as you recommended.
I hope to fix the problem.
Dong Ho
Thank-you, that information was very helpful.
I have committed what I think should be the necessary changes to support your linux-aarch64 target to the default branch of our Git repository. Since you followed our how-to installation instructions you should be able to pull those modifications into your copy and build it as follows:
epics@epics-desktop:~$ cd ~/EPICS/epics-base
epics@epics-desktop:~/EPICS/epics-base$  git pull
epics@epics-desktop:~/EPICS/epics-base$  make
If the build stops and displays one or more error messages, please copy the errors and the build command immediately before them into an email and send it to the EPICS tech-talk list so we can try to help fix it.
If the build finishes without any obvious error messages, please try running our built-in unit tests like this:
epics@epics-desktop:~/EPICS/epics-base$  make -s runtests
This will run several blocks of tests to check different parts of the software, displaying the results after each block. Please email us the results if you get any failures, and let us know if they all pass.
Good luck, and thank-you!
- Andrew
Complexity comes for free, simplicity you have to work for.
/home/epics/EPICS/epics-base/test/tools/O.linux-aarch64
Snippets.t .. ok
All tests successful.
Files=1, Tests=29,  2 wallclock secs ( 0.06 usr  0.01 sys +  1.33 cusr  0.18 csys =  1.58 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/libcom/test/O.linux-aarch64
epicsUnitTestTest.t ........... ok
epicsTypesTest.t .............. ok
epicsInlineTest.t ............. ok
epicsCalcTest.t ............... ok
epicsAlgorithmTest.t .......... ok
epicsMathTest.t ............... ok
epicsMMIOTest.t ............... ok
epicsEllTest.t ................ ok
epicsEnvTest.t ................ ok
epicsEnvUnsetTest.t ........... ok
epicsErrlogTest.t ............. ok
epicsStdioTest.t .............. ok
epicsStdlibTest.t ............. ok
epicsSockResolveTest.t ........ ok
epicsStringTest.t ............. ok
epicsTimeTest.t ............... ok
epicsTimeZoneTest.t ........... ok
epicsThreadTest.t ............. ok
epicsThreadClassTest.t ........ ok
epicsThreadOnceTest.t ......... ok
epicsThreadPriorityTest.t ..... ok
epicsThreadPrivateTest.t ...... ok
epicsThreadHooksTest.t ........ ok
epicsThreadPoolTest.t ......... ok
epicsExitTest.t ............... ok
epicsTimerTest.t .............. ok
ringPointerTest.t ............. ok
ringBytesTest.t ............... ok
epicsEventTest.t .............. ok
epicsMutexTest.t .............. ok
epicsSpinTest.t ............... ok
epicsAtomicTest.t ............. ok
macDefExpandTest.t ............ ok
cvtFastTest.t ................. ok
macLibTest.t .................. ok
aslibtest.t ................... ok
macLib.t ...................... ok
taskwdTest.t .................. ok
blockingSockTest.t ............ ok
epicsMessageQueueTest.t ....... ok
epicsStackTraceTest.t .........
not ok  3 - dumping global symbols
not ok  4 - dumping local symbols
not ok  5 - dumping addresses
Failed 3/5 subtests
ipAddrToAsciiTest.t ........... ok
osiSockTest.t ................. ok
testexecname.t ................ ok
yajlTest.t .................... ok
iocshTest.t ................... ok
epicsLoadTest.t ............... ok
nonEpicsThreadPriorityTest.t .. ok
Test Summary Report
epicsStackTraceTest.t       (Wstat: 0 Tests: 5 Failed: 3)
  Failed tests:  3-5
Files=48, Tests=4274, 200 wallclock secs ( 1.61 usr  0.17 sys +  3.66 cusr  2.52 csys =  7.96 CPU)
Result: FAIL
/home/epics/EPICS/epics-base/modules/pvData/testApp/O.linux-aarch64
testThread.t ............ ok
testEvent.t ............. ok
testTimer.t ............. ok
testBitSet.t ............ ok
testOverrunBitSet.t ..... ok
testByteBuffer.t ........ ok
testBaseException.t ..... ok
testSharedVector.t ...... ok
testDebugPtr.t .......... ok
testSerialization.t ..... ok
testTimeStamp.t ......... ok
testTypeCast.t .......... ok
testUnitTest.t .......... ok
testjson.t .............. ok
test_reftrack.t ......... ok
testanyscalar.t ......... ok
testprinter.t ........... ok
testBitSetUtil.t ........ ok
testIntrospect.t ........ ok
testPVType.t ............ ok
testStandardField.t ..... ok
testStandardPVField.t ... ok
testPVData.t ............ ok
testPVUnion.t ........... ok
testConvert.t ........... ok
testPVScalarArray.t ..... ok
testPVStructureArray.t .. ok
testOperators.t ......... ok
testFieldBuilder.t ...... ok
testValueBuilder.t ...... ok
testProperty.t .......... ok
testCreateRequest.t ..... ok
Files=32, Tests=2653, 68 wallclock secs ( 0.89 usr  0.12 sys +  0.80 cusr  0.22 csys =  2.03 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/ioc/db/O.linux-aarch64
dbScanTest.t ............... ok
dbShutdownTest.t ........... ok
dbPutLinkTest.t ............ ok
dbLockTest.t ............... ok
dbStressTest.t ............. ok
testdbConvert.t ............ ok
callbackTest.t ............. ok
callbackParallelTest.t ..... ok
dbStateTest.t .............. ok
dbServerTest.t ............. ok
dbCaStatsTest.t ............ ok
dbCaLinkTest.t ............. ok
scanIoTest.t ............... ok
dbChannelTest.t ............ ok
dbChArrTest.t .............. ok
chfPluginTest.t ............ ok
arrShorthandTest.t ......... ok
recGblCheckDeadbandTest.t .. ok
testPutGetTest.t ........... ok
dbStaticTest.t ............. ok
Files=20, Tests=2873, 80 wallclock secs ( 1.06 usr  0.09 sys + 23.20 cusr 16.84 csys = 41.19 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/ioc/dbtemplate/O.linux-aarch64
msi.t .. ok
Files=1, Tests=12,  0 wallclock secs ( 0.06 usr  0.00 sys +  0.06 cusr  0.02 csys =  0.14 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/std/rec/O.linux-aarch64
arrayOpTest.t ........... ok
recMiscTest.t ........... ok
linkRetargetLinkTest.t .. ok
linkInitTest.t .......... ok
compressTest.t .......... ok
asyncSoftTest.t ......... ok
softTest.t .............. ok
seqTest.t ............... ok
asTest.t ................ ok
analogMonitorTest.t ..... ok
scanEventTest.t ......... ok
regressTest.t ........... ok
simmTest.t .............. ok
mbbioDirectTest.t ....... ok
asyncproctest.t ......... ok
netget.t ................ ok
Files=16, Tests=4392, 20 wallclock secs ( 1.09 usr  0.09 sys +  1.84 cusr  0.46 csys =  3.48 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/std/link/O.linux-aarch64
lnkStateTest.t .. ok
lnkCalcTest.t ... ok
Files=2, Tests=58,  1 wallclock secs ( 0.09 usr  0.00 sys +  0.06 cusr  0.03 csys =  0.18 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/std/filters/O.linux-aarch64
tsTest.t .... ok
dbndTest.t .. ok
arrTest.t ... ok
syncTest.t .. ok
decTest.t ... ok
Files=5, Tests=1809,  3 wallclock secs ( 0.39 usr  0.02 sys +  0.18 cusr  0.07 csys =  0.66 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/database/test/tools/O.linux-aarch64
Base.t ........ ok
Breaktable.t .. ok
DBD.t ......... ok
Device.t ...... ok
Driver.t ...... ok
Function.t .... ok
Menu.t ........ ok
Recfield.t .... ok
Recordtype.t .. ok
Registrar.t ... ok
Variable.t .... ok
Files=11, Tests=293,  2 wallclock secs ( 0.17 usr  0.01 sys +  1.39 cusr  0.18 csys =  1.75 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pvAccess/testApp/O.linux-aarch64
testAtomicBoolean.t ..... ok
testHexDump.t ........... ok
testInetAddressUtils.t .. ok
configurationTest.t ..... ok
testFairQueue.t ......... ok
testWildcard.t .......... ok
testChannelAccess.t ..... ok
testCodec.t ............. ok
testRPC.t ............... ok
testServerContext.t ..... ok
testmonitorfifo.t ....... ok
testsharedstate.t ....... ok
Files=12, Tests=6381, 29 wallclock secs ( 1.15 usr  0.05 sys +  2.51 cusr  0.60 csys =  4.31 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pvAccess/testCa/O.linux-aarch64
testCaProvider.t .. ok
Files=1, Tests=143,  1 wallclock secs ( 0.08 usr  0.00 sys +  0.08 cusr  0.03 csys =  0.19 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/normativeTypes/test/O.linux-aarch64
ntfieldTest.t ............... ok
ntscalarTest.t .............. ok
ntscalarArrayTest.t ......... ok
ntnameValueTest.t ........... ok
ntmultiChannelTest.t ........ ok
ntscalarMultiChannelTest.t .. ok
nttableTest.t ............... ok
ntndarrayTest.t ............. ok
ntmatrixTest.t .............. ok
ntenumTest.t ................ ok
ntunionTest.t ............... ok
ntaggregateTest.t ........... ok
ntattributeTest.t ........... ok
ntndarrayAttributeTest.t .... ok
ntcontinuumTest.t ........... ok
nthistogramTest.t ........... ok
ntutilsTest.t ............... ok
validatorTest.t ............. ok
Files=18, Tests=687,  1 wallclock secs ( 0.28 usr  0.04 sys +  0.44 cusr  0.12 csys =  0.88 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pvDatabase/test/O.linux-aarch64
testPlugin.t ......... ok
testPVCopy.t ......... ok
testPVRecord.t ....... ok
testExampleRecord.t .. ok
testLocalProvider.t .. ok
testPVAServer.t ...... ok
Files=6, Tests=107,  0 wallclock secs ( 0.11 usr  0.01 sys +  0.16 cusr  0.04 csys =  0.32 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pva2pva/p2pApp/O.linux-aarch64
testmon.t .. ok
Files=1, Tests=79,  0 wallclock secs ( 0.08 usr  0.00 sys +  0.02 cusr  0.00 csys =  0.10 CPU)
Result: PASS
/home/epics/EPICS/epics-base/modules/pva2pva/testApp/O.linux-aarch64
testweak.t ......... ok
testtest.t ......... ok
testpvif.t ......... ok
testpdb.t .......... ok
testpvalink.t ...... ok
testgroupconfig.t .. ok
testdbf_copy.t ..... ok
Test Summary Report
testpvif.t       (Wstat: 0 Tests: 88 Failed: 0)
  TODO passed:   35
Files=7, Tests=342,  3 wallclock secs ( 0.20 usr  0.02 sys +  0.39 cusr  0.10 csys =  0.71 CPU)
Result: PASS
Test failures were reported in:
configure/RULES_TOP:54: recipe for target 'runtests' failed
Re: Problem with installing epics base on Jetson nano Johnson, Andrew N. via Tech-talk
Problem with installing epics base on Jetson nano 신동호 via Tech-talk
Prev: JUMO diraTRON 104 Modbus Patrick Oppermann via Tech-talk
Next: Re: Problem with installing epics base on Jetson nano Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: Problem with installing epics base on Jetson nano Johnson, Andrew N. via Tech-talk
ANJ, 16 Sep 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
