1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: ASLO doesn't work
From: Maren Purves via Tech-talk <tech-talk at aps.anl.gov>
To: Vishnu Patel <patel.vishnu at hotmail.com>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 16 Sep 2020 23:55:52 -1000
Can you just change it in the display?
Aloha,
Maren
On Wed, Sep 16, 2020 at 11:10 PM Vishnu Patel via Tech-talk <tech-talk at aps.anl.gov> wrote:
I have tried to divide the value of ai record using ASLO field. But It doesn't work.
record(ai, "AI0") {
    field(DTYP,"s7nodave")
    field(INP,"@lcpcPLC DB6.DBD36 float")
    field(LINR,"LINEAR")
    field(HOPR,"20")
    field(LOPR,"0")
    field(ASLO,"0.001")
    field(PREC,"4")
    field(SCAN,"1 second")
    field(EGU,"Bar")
    field(EGUF,"32767")
    field(EGUL,"-32768")
my input is 1003.124 and it gives same only even i change ASLO to 1.
The PLC the value is 1003.124 in mBar, i have to display as 1.0031 Bar.
I am missing something to set.
Thanks
Vishnu
ASLO doesn't work Vishnu Patel via Tech-talk
Prev: ASLO doesn't work Vishnu Patel via Tech-talk
Next: Re: ASLO doesn't work Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 17 Sep 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
