You might be able to make it work by doing the following:
1. Set m1's RDBL field to m11.REP
2. Set m1's RRES field to whatever is required to convert between
m11.REP and m1's EGU.
3. Set m1's URIP = Yes and UEIP = No
Kevin
On 9/29/20 8:55 AM, Guilherme Jovanini Montagner wrote:
> Hi Kevin
> Thank you for your response.
> I tried with UEIP = 1, but then it seems to use the motor 1 encoder (which is just the phase value, or open loop value), and not the m11 encoder that I have setup.
> Then it disregards the m11 encoder reading
> +55 19 99806.9117
> +55 19 2517.8911
> guilherme at setup.com.br
> Labview Certified Developer
- Re: Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
- Implementing closed loop on EPICS level Guilherme Jovanini Montagner via Tech-talk
- Re: Implementing closed loop on EPICS level Peterson, Kevin M. via Tech-talk
<2020>
2025
<2020>
2025
