1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: How can I use pvapy or p4p to monitor multiple PVS
From: Michael Davidsaver via Tech-talk <tech-talk at aps.anl.gov>
To: "qt980319 at mail.ustc.edu.cn" <qt980319 at mail.ustc.edu.cn>
Cc: "sunxk at ustc.edu.cn" <sunxk at ustc.edu.cn>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 13 Oct 2020 11:32:37 -0700
On 10/12/20 8:54 PM, Mark Rivers via Tech-talk wrote:
> However, in the process of testing it, it was found that only a single PV can be monitored
> In p4p can’t you just call the monitor() method multiple times, once for each PV that you want to monitor?
As Mark says, it should be as simple as calling monitor() again.
I wonder though about the mention of 'multiChannel'.  While most PVA servers which support the
GET network operation on a given PV also support MONITOR, this is not required (though imo. it
should be).  So it is entirely possible for a custom PVA server not to implement the MONITOR
operation.  There is nothing a client can do about this.
Which PVA server is involved here?
> In pvapy can’t you just create a Channel object for each PV, and call it’s monitor() method?
> Mark
> Sent from my iPhone
> On Oct 12, 2020, at 10:18 PM, 秦天 via Tech-talk <tech-talk at [email protected] <tech-talk at [email protected]> wrote:
> Subject: How can I use pvapy or p4p to monitor multiple PVS
> From:Sky Qin<qt980319 at mail.ustc.edu.cn>
> To:tech-talk at aps.anl.gov
> Date:Tue,13 October 2020
> Hi EPICS community, I am trying to monitor several EPICS7 PVs using pvapy or p4p. pvapy and p4p are described below:
> http://epics-pvdata.sourceforge.net/docbuild/4.7.0/pvaPy/
> https://mdavidsaver.github.io/p4p/
> However, in the process of testing it, it was found that only a single PV can be monitored.The method of connecting to multiple PV is multiChannel,but there is only get(),  no monitor method. What method can be used to monitor a large number of PV?
> Best regards,
> Sky Qin
> 下载视频
How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <tech-talk at aps.anl.go
Re: How can I use pvapy or p4p to monitor multiple PVS Mark Rivers via Tech-talk
Prev: Re: EPICS timestamp in the archiver appliance Brown, Garth via Tech-talk
Next: Curious about EPICS IOC on RTOS for x86 Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: How can I use pvapy or p4p to monitor multiple PVS Marty Kraimer via Tech-talk
Next: Re: How can I use pvapy or p4p to monitor multiple PVS 秦天 via Tech-talk <tech-talk at aps.anl.go
ANJ, 13 Oct 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
