I'm trying to set some attributes using XML, and I am had problem with some pvs.
Example XML file:
<?xml version="1.0" standalone="no" ?>
<!-- Attributes -->
<Attributes
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance";
xsi:noNamespaceSchemaLocation="../../../../../ADCore/XML_schema/NDAttributes.xsd"
<Attribute name="NumExposures" type="EPICS_PV" source="CAT:S:cam1:NumExposures_RBV" datatype="DBR_NATIVE" description="Number of exposures manufacturer"/>
<Attribute name="m1_velocity" type="EPICS_PV" source="CAT:S:m1.VELO" datatype="DBR_NATIVE" description="Motor 1 Velocity"/>
<Attribute name="photodiode" type="EPICS_PV" source="CAT:C:RIO03:0215B:ai1 datatype="DBR_NATIVE" description="BIM01 - Photodiode"/>
</Attributes>
The two first lines and works fine. The first is a PV from simDetector IOC, (The same IOC where I'm using the HDF5Plugin and using the XML file). The second is a motorRecord Simulated IOC, that is running in the same host that first ioc.
But, the last one, is returning the value "nan". This specific IOC that provide this PV is running in another host. However, I can read the value using caget:
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ caget CAT:C:RIO03:9215B:ai1
CAT:C:RIO03:9215B:ai1 0.000247466
douglas.araujo@cat-gui:/usr/local/epics/apps/config$ cainfo CAT:C:RIO03:9215B:ai1
State: connected
Host: s-cat-c-rio03.abtlus.org.br:5064
Access: read, write
Native data type: DBF_DOUBLE
Request type: DBR_DOUBLE
Element count: 1
I'm using the 3.3.1 ADCore Version.
I read the documentation and saw that this is a behavior when the pv is not connected. But my pv is connected. Need I set some parameter on ioc to get PV from another host ? Or someone have any ideas about this behaivor ??
Regards.
Aviso Legal: Esta mensagem e seus anexos podem conter informações confidenciais e/ou de uso restrito. Observe atentamente seu conteúdo e considere eventual consulta
ao remetente antes de copiá-la, divulgá-la ou distribuí-la. Se você recebeu esta mensagem por engano, por favor avise o remetente e apague-a imediatamente.
Disclaimer: This email and its attachments may contain confidential and/or privileged information. Observe its content carefully and consider possible querying
to the sender before copying, disclosing or distributing it. If you have received this email by mistake, please notify the sender and delete it immediately.
- Re: Read PV value Attributes XML Hugo Slepicka via Tech-talk
- RE: Read PV value Attributes XML Mark Rivers via Tech-talk
Re: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Ralph Lange via Tech-talk
<2020>
AW: [EXTERNAL] Experiences using RS-485 Multi-Drop with StreamDevice? Zimoch Dirk (PSI) via Tech-talk
<2020>
