1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: CSS Build error
From: Vishnu Patel via Tech-talk <[email protected]>
To: tech-talk <[email protected]>
Date: Wed, 28 Oct 2020 05:19:15 +0000
   I am trying to compile sns-css code from
i have downloaded diirt.
But gives maven-osgi-bundles error
[INFO] org.diirt.p2 ....................................... SUCCESS [ 32.956 s]
[INFO] ------------------------------------------------------------------------
[INFO] BUILD SUCCESS
[INFO] Total time: 02:27 min
[INFO] Finished at: 2020-10-28T10:32:23+05:30
[INFO] Final Memory: 279M/6773M
653.63user 56.78system 2:30.27elapsed 472%CPU (0avgtext+0avgdata 3098396maxresident)k
0inputs+254760outputs (0major+4147920minor)pagefaults 0swaps
test2
make.sh: 64: cd: can't cd to maven-osgi-bundles
[INFO] Scanning for projects...
[INFO] BUILD FAILURE
[INFO] Total time: 0.109 s
[INFO] Finished at: 2020-10-28T10:32:26+05:30
[INFO] Final Memory: 22M/1963M
[ERROR] The goal you specified requires a project to execute but there is no POM in this directory (/home/trainee/eclipse-workspace/cssProj). Please verify you invoked Maven from the correct directory. -> [Help 1]
I have downloaded
and use the  maven-osgi-bundles
it gives error
[INFO] org.diirt.p2 ....................................... SUCCESS [ 32.299 s]
[INFO] Finished at: 2020-10-28T10:43:10+05:30
[INFO] Final Memory: 278M/6712M
662.68user 55.32system 2:30.06elapsed 478%CPU (0avgtext+0avgdata 3096824maxresident)k
0inputs+254760outputs (0major+4208493minor)pagefaults 0swaps
test2
[ERROR] [ERROR] Some problems were encountered while processing the POMs:
[FATAL] Non-resolvable parent POM for org.csstudio:maven-osgi-bundles:[unknown-version]: Could not find artifact org.csstudio:cs-studio:pom:4.6.0-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ line 10, column 11
[ERROR] The build could not read 1 project -> [Help 1]
[ERROR]
[ERROR]   The project org.csstudio:maven-osgi-bundles:[unknown-version] (/home/trainee/eclipse-workspace/cssProj/maven-osgi-bundles/pom.xml) has 1 error
[ERROR]     Non-resolvable parent POM for org.csstudio:maven-osgi-bundles:[unknown-version]: Could not find artifact org.csstudio:cs-studio:pom:4.6.0-SNAPSHOT and 'parent.relativePath' points at wrong local POM @ line 10, column 11 -> [Help 2]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/ProjectBuildingException
[ERROR] [Help 2] http://cwiki.apache.org/confluence/display/MAVEN/UnresolvableModelException
I am new in the CS-Studio compilation.
Please guide me to compile CS-Studio
Thanks
Vishnu
Prev: Re: Build system prepending $(TOP) to make path on win32-x86 Johnson, Andrew N. via Tech-talk
Next: EPICS IOC and its client application with ONLY IPv6 Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: vscode extension for EPICS Victor Nadot via Tech-talk
