1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
From: "Manoussakis, Adamandios via Tech-talk" <tech-talk at aps.anl.gov>
To: Jeong Han Lee <citadel.lee at gmail.com>
Cc: tech-talk <tech-talk at aps.anl.gov>
Date: Thu, 29 Oct 2020 01:20:40 +0000
Just an update it seems
EPICS_CA_AUTO_ADDR_LIST=YES
EPICS_CA_ADDR_LIST=localhost
must be in the archappl.conf file otherwise it does not connect to the PVs
I dont quite understand why since I thought it is just setting environment variables from that script and having them exported in the ~/.profile should be enough?  Maybe Han you can clear this up for me why the install looks in this archappl.conf file and not at the env variables that are set in ~/.profile?
Thanks
Sent: Wednesday, October 28, 2020 6:04 PM
To: Manoussakis, Adamandios <manoussakis1 at llnl.gov>
Cc: Wang, Lin <wanglin at ihep.ac.cn>; tech-talk <tech-talk at aps.anl.gov>
Thank you all, if you leave comments or proposals in issue, I will
update them in my repository.
I am glad this repo helps you to figure out archiver appliances at the
beginning.
Han
On Wed, Oct 28, 2020 at 6:00 PM Manoussakis, Adamandios via Tech-talk
<tech-talk at aps.anl.gov> wrote:
> IT WORKS!  Just need to track down which change made it work now haha.  But it has something to do with either changing the AUTO_ADDR back to NO or adding the env variables to the archappl.conf file.  Will update once I figure out which one it is.  But thank you both for helping me debug it was extremely helpful!
> ________________________________
> From: Manoussakis, Adamandios <manoussakis1 at llnl.gov>
> Sent: Wednesday, October 28, 2020 5:53 PM
> To: Wang, Lin <wanglin at ihep.ac.cn>
> Hi Lin,
> currently I have in my ~/.profile
> export EPICS_CA_AUTO_ADDR_LIST=YES
> export EPICS_CA_ADDR_LIST=localhost
> do I need to have these located in the archappl.conf instead of being exported through profile, seems like the scripts do the same thing at the end of the day just export the env variables?
> Thanks
> From: Wang, Lin <wanglin at ihep.ac.cn>
> Sent: Wednesday, October 28, 2020 5:41 PM
> Hello,
> You may also want to make sure the EPICS-related environment variable (EPICS_CA_AUTO_ADDR_LIST and EPICS_CA_ADDR_LIST) loaded by Archiver Appliance is correct, probably in your case "localhost" should be in the EPICS_CA_ADDR_LIST address list.
> For example, in the Archiver Appliance single machine installation sample, the following line locates in sampleStartup.sh file, and setEPICSEnv.sh file sets the two environment variables above. In your case this line can be in the conf file,
> source /opt/local/setEPICSEnv.sh
> Regards,
> Lin
> -----Original Messages-----
> From:"Manoussakis, Adamandios via Tech-talk" <tech-talk at aps.anl.gov>
> Sent Time:2020-10-28 14:45:17 (Wednesday)
> To: tech-talk <tech-talk at aps.anl.gov>
> Cc:
> Subject: Archiver Appliance PVs never connect to be archived, always "Initial Sampling"
> Hello All,
> I have started to build the epics archiver appliance following Hans repo at https://github.com/jeonghanlee/epicsarchiverap-env.  Everything seems to be working great with the application and I am able to access the archiver web application just fine.  I start up a basic softIoc with a couple PVs and my pyDM widget is able to control and access them just fine but I cannot get them to be archived by the appliance.  I can also use caget/camonitor/caput without any issue to manipulate the softIoc.   I saw another post about checking the ports in the appliances.xml but that seems to be correct from what I can tell.  I tried to look through the logs in /opt/epicsarchiverap/engine mgmt etl retrieval but I didnt see any errors that stood out.  I am not sure if its a connection issue with the ca and the archiver or a record thing I am missing but any advice would be helpful.  I have tried using ca://calc:a , calc:a but no luck getting it to archive.
> appliances.xml
> <appliances>
>    <appliance>
>      <identity>appliance0</identity>
>      <cluster_inetport>localhost:16670</cluster_inetport>
>      <mgmt_url>http://localhost:17665/mgmt/bpl</mgmt_url>
>      <engine_url>http://localhost:17666/engine/bpl</engine_url>
>      <etl_url>http://localhost:17667/etl/bpl</etl_url>
>      <retrieval_url>http://localhost:17668/retrieval/bpl</retrieval_url>
>      <data_retrieval_url>http://localhost:17668/retrieval</data_retrieval_url>
>    </appliance>
> </appliances>
> also checked the conf file for archappl
> JAVA_HOME="/usr/lib/jvm/java-11-openjdk-amd64"
> JAVA_OPTS="-Djava.security.egd=file:/dev/./urandom"
> CATALINA_HOME="/usr/share/tomcat9"
> CATALINA_OPTS="-XX:MaxMetaspaceSize=256m -Xms512m -Xmx512m -XX:+UseG1GC -ea"
> ARCHAPPL_APPLIANCES="/opt/epicsarchiverap/appliances.xml"
> ARCHAPPL_POLICIES="/opt/epicsarchiverap/policies.py"
> ARCHAPPL_PROPERTIES_FILENAME="/opt/epicsarchiverap/archappl.properties"
> ARCHAPPL_MYIDENTITY="appliance0"
> ARCHAPPL_STORAGE_TOP="/arch"
> ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
> ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
> ARCHAPPL_LONG_TERM_FOLDER="/arch/lts/ArchiverStore"
> Example Record for one of the PVs
> record(ao,"$(INST):a"){
> field(DESC,"Input A")
> field(DTYP,"Soft Channel")
> field(PREC,1)
> field(DRVH,10)
> field(HOPR,10)
> field(VAL,0)
> field(LOPR,-10)
> field(DRVL,-10)
> field(UDF,1)
> field(FLNK,"$(INST):sum")
> field(ADEL,0)
> field(MDEL,0)
> Thanks
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Wang, Lin via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
Prev: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
Next: Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 28 Oct 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
