Hi Murali,
I have one naive question about the following situation.
After the archiver was started, in case that I have to change these variables.
* Should I restart the service after changing these variables?
* If so, is there any way to update them while the archiver is running?
Best,
Han
On Fri, Oct 30, 2020 at 7:55 AM Shankar, Murali via Tech-talk
<tech-talk at aps.anl.gov> wrote:
> The archiver needs a proper EPICS setup for it to connect to the IOC's. The engine's arch.log should print out the actual CA configuration being used so you can look there to see if the EPICS setup was inherited correctly from your .profile.
> Regards,
> Murali
- Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
- RE: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Shankar, Murali via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Manoussakis, Adamandios via Tech-talk
<2020>
<2020>
ANJ, 30 Oct 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
