Hi Andrew,
Okay, thanks, I'll wait to hear back. The pc686 and others mentioned are what we want to test.
-Matt
On Fri, Oct 30, 2020 at 1:30 PM Johnson, Andrew N. < anj at anl.gov> wrote:
Hi Matt,
On Oct 30, 2020, at 4:59 PM, Matt Rippa via Tech-talk < tech-talk at aps.anl.gov> wrote:
I'd like to start testing EPICS7 on RTEMS5.1. I think these are the latest versions slated for support. Is there guidance setting this up from the EPICS community? If not, I pretty much know what to do, but
I'll be winging it a little --merging rtems specific instructions with epics specific instructions.
My target bsp's include pc386, beatnik, 3100 and motorola_shared (mvme_2700).
That would be great, but unfortunately we aren’t quite ready for testers yet. Right now we have 3 different versions of the RTEMS-5 port that need to be reconciled and merged into the 7.0 branch. There is a meeting of the Core Developers group on Wednesday
when I plan to discuss doing that, assuming all 3 of the relevant developers are able to attend (please check the Agenda guys!), so hopefully it won’t be too much longer.
I will try to remember to let you and the community know as soon as we have the RTEMS-5 port merged.
BTW RTEMS-5 now provides a pc686 BSP, would you be able to run that instead of the pc386 or do you need the older one for the particular CPU boards you’re using?
- Andrew
Complexity comes for free, simplicity you have to work for.
- EPICS7 and RTEMS5.1 Testing Matt Rippa via Tech-talk
- Re: EPICS7 and RTEMS5.1 Testing Johnson, Andrew N. via Tech-talk
Re: Archiver Appliance PVs never connect to be archived, always "Initial Sampling" Jeong Han Lee via Tech-talk
Accessing info fields via CA/PVA Simon Rose via Tech-talk
<2020>
2025
<2020>
2025
ANJ, 02 Nov 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
