1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Accessing info fields via CA/PVA
From: "Johnson, Andrew N. via Tech-talk" <tech-talk at aps.anl.gov>
To: Simon Rose <Simon.Rose at ess.eu>
Cc: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 2 Nov 2020 18:13:39 +0000
Hi Simon,
On Nov 2, 2020, at 5:12 AM, Simon Rose via Tech-talk <tech-talk at aps.anl.gov> wrote:
Is it possible to read info fields on a DB record via either Channel Access or PV Access? I note that it is possible to read them from within the IOC shell via the dbli function added in 7.0.1.1, but I am wondering if it is possible to read them over a network and not from within the IOC.
That was never my intention when I originally added info items to the database, but it would have been quite a bit harder back then. Other people have also suggested it since and I don’t see any problems with making them readable from outside, but I’m now aware of any work to actually implement that.
It occurs to me that the simplest way to support this might be to create a server-side filter that fetches the info tag data instead of trying to embed this into the IOC code. I just filed an entry in our bug database with some suggestions and things to be aware of for anyone who wants to have a go at writing such a filter. The result could be written to be support any 3.15 or later version of Base, although the 7.0 branch does have some info-related APIs that are not present in 3.15.
- Andrew
Complexity comes for free, simplicity you have to work for.
Accessing info fields via CA/PVA Simon Rose via Tech-talk
Prev: EPICS How-To , Installation on Windows John Dobbins via Tech-talk
Next: RE: EPICS How-To , Installation on Windows Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Accessing info fields via CA/PVA Simon Rose via Tech-talk
Next: LabView-EPICS Integration using SoftIoc Mostafa, Jalal (IPE) via Tech-talk
ANJ, 02 Nov 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
