Subject: Re: LabView-EPICS Integration using SoftIoc
From: "Mostafa, Jalal \(IPE\) via Tech-talk" <[email protected]>
To: "Akeroyd, Freddie (STFC,RAL,ISIS)" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 3 Nov 2020 15:34:47 +0100
Hi Freddie,
Thank you! This is what I need indeed. One disadvantage is NI CVI which
this library use is paid as far as I know.
No alternative for CVI? Can CVI be replaced by an TCP/IP-based protocol
without shared variables?
Best,
Jalal
On ٢‏/١١‏/٢٠٢٠ ١١:٥٦ م, Akeroyd, Freddie (STFC,RAL,ISIS) wrote:
> Hi Jalal,
> There is a slight variation on (2)  http://epics.isis.stfc.ac.uk/doxygen/NetShrVar/  which is an EPICS asyn driver that talks directly to shared variables, so gives you a bit more flexibility that the NI EPICS implementation. If TSE is -2 the EPICS timestamp is taken from the shared variable timestamp, and records can be I/O Intr scan and update directly from the shared variable. You can also map shared variable alarms to EPICS alarms, but it looks like I haven't  updated the web documentation to mention that yet.
> Regards,
> Freddie
>> -----Original Message-----
>> From: Tech-talk <[email protected]> On Behalf Of Mostafa, Jalal
>> (IPE) via Tech-talk
>> Sent: 02 November 2020 13:44
>> To: [email protected]
>> Subject: LabView-EPICS Integration using SoftIoc
>> Hi all!
>> We have many systems from NI that we would like to integrate with EPICS for
>> the KATRIN experiment (katrin.kit.edu) The old control system was written in
>> LabView but we would like to replace it with EPICS without rewriting the code
>> again. Therefore, we are looking for a nice LabView-EPICS integration.
>> We have seen two options for LabView:
>> - CALAB which does not work with realtime devices
>> - Official NI EPICS module. It is good but I can list several problems:
>> huge loss of EPICS features (it is only an implementation of CA plus alarming,
>> the other metadata and configuration fields are not available)
>> - not very developer-friendly (adding/removing PVs relies on shared variables
>> so it is time consuming)
>> Another two solutions we thought of:
>> 1. Using AsynDriver and communicate with the realtime device using a TCP
>> protocol 2. Running an EPICS server on the realtime device using NI EPICS
>> module then shadowing it with a SoftIoc using CA links.
>> (a softIoc server running with input and output records to read and write to the
>> original LabView EPICS server)
>> I have several concerns here:
>> - Am I missing any other way to integrate LabView with EPICS? I would like to
>> hear from your experiences.
>> - Although solution (1) is time consuming, I am in favor of it but let's check if
>> we can do it more easily with solution (2). Anyway, can the experts comment
>> on its feasibility?
>> - Solution (2): What do you think about performance? Alarms? I/O Intr are not
>> available on a softIoc, so the developer has to use periodic SCAN. How can I
>> add custom SCAN periods?
>> Thanks for your help.
>> Best,
>> Jalal
> This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
Attachment: 0x439301476F7FF6A4.asc
Description: application/pgp-keys
Attachment: signature.asc
Description: OpenPGP digital signature
RE: LabView-EPICS Integration using SoftIoc Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
LabView-EPICS Integration using SoftIoc Mostafa, Jalal (IPE) via Tech-talk
Prev: Re: LabView-EPICS Integration using SoftIoc Dawood Awny Dawood Alnajjar via Tech-talk
Next: RE: ADDexala build error Mark Rivers via Tech-talk
Next: RE: LabView-EPICS Integration using SoftIoc Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
