Subject: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message
From: Abdalla Ahmad via Tech-talk <[email protected]>
To: "[email protected]" <[email protected]>, Mark Rivers <[email protected]>
Date: Tue, 3 Nov 2020 16:04:07 +0000
Hi
I am writing an AsynPortDriver class for the libera spark and I would like to do the waveforms data acquisition in a separate thread (attached is my initial implementation). Whenever a large data size requested (Using command "ADC 100" for example), the IOC crashes with the following message:
dbGetLinkValue: Illegal link type -13664
Segmentation fault
Noticing that this number is random at every time the IOC crashes. Right now I am trying to enable core dumps on my machine (for some reason they are not dumped), but in the meantime, what is wrong with my thread implementation?
Is it possible to have a variable length waveform record in EPICS? If yes, how does asyn implements this?
Best Regards,
Abdalla.
void LiberaSpark::performDAQ()
	printf("DAQ Thread initialized!\n");
	string line = "";
	char* command = (char*) "ADC 200\n";
	int status;
	ssize_t bytes;
	char buffer[48];
	struct pollfd polling_fds[1];
	polling_fds[0].fd = this->device_socket;
	polling_fds[0].events = POLLIN;
	polling_fds[0].revents = 0;
	while(true)
		lock();
		pthread_mutex_lock(&device_mutex);
		bytes = write(device_socket, command, strlen(command));
		status = poll(polling_fds, 1, 1);
		int i = 0;
		while(status > 0)
			memset(buffer, 0, sizeof(buffer));
			bytes = read(device_socket, buffer, sizeof(buffer));
			buffer[bytes - 1] = '\0';
			stringstream ss(buffer);
			cout << ss.str() << endl;
			while(ss >> line)
				if(i % 4 == 0)
					adc_a[i / 4] = atoi(line.c_str());
				i++;
		pthread_mutex_unlock(&device_mutex);
		unlock();
		sleep(1);
RE: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
Prev: RE: ADDexala build error Mark Rivers via Tech-talk
Next: Re: ADDexala build error John Dobbins via Tech-talk
Prev: RE: ADDexala build error Engbretson, Mark S. via Tech-talk
Next: RE: AsynPortDriver separate thread causes Segmentation fault with "dbGetLinkValue" error message Mark Rivers via Tech-talk
