Hi Steve,
> We are interested in getting accurate timestamps per image from the camera. I've set the TimeStampMode PV to Camera. I hope this isn't too simple a question but which PV(s) should show a timestamp derived from the camera in this mode?
If you send the image from the camera to any plugin, then that plugin will have a timestamp PV for each NDArray. The PV is TimeStamp_RBV. It is typically the EPICS timestamp that the image was collected as a double. It is ~microsecond precision. It can also be a timestamp from the camera, in which case the epoch will be different, perhaps when the camera was last power-cycled, etc.
corvette:~>camonitor -e10 13PE1:TIFF1:TimeStamp_RBV
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:12.677007 9.7337545268e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.351011 9.7337548635e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.420621 9.7337548642e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.486820 9.7337548649e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.554361 9.7337548655e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.625862 9.7337548662e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.685514 9.7337548669e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.755956 9.7337548676e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.821045 9.7337548682e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.888365 9.7337548689e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:46.954892 9.7337548695e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:47.030338 9.7337548702e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:47.085115 9.7337548709e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:47.154083 9.7337548715e+08
13PE1:TIFF1:TimeStamp_RBV 2020-11-04 16:04:47.220255 9.7337548722e+08
Each NDArray also has an epicsTS field which always the EPICS timestamp when the image was collected. That is not available as a PV (because it is 2 32-bit integers), but it is available in TIFF files, HDF5 files, and netCDF files written by areaDetector.
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Kinder, Steve (STFC,DL,TECH) via Tech-talk <tech-talk at aps.anl.gov>
Sent: Wednesday, November 4, 2020 3:44 PM
To: tech-talk at aps.anl.gov
Subject: ADVimba camera timestamps
I have a Manta G235-B camera running on a RPi4 using ADVimba. We are interested in getting accurate timestamps per image from the camera. I've set the TimeStampMode PV to Camera. I hope this isn't too simple a question but which PV(s) should show a timestamp derived from the camera in this mode?
I have been trying to get derived ArrayData to have timestamps from the camera. To test this I am just doing:
$ camonitor -# 1 SHK78-TEST-01:CAM1:ArrayData
SHK78-TEST-01:CAM1:ArrayData 2020-11-04 16:23:00.867192 1 59
This is clearly too naive approach as the timestamps are just the system time. Any advice would be much appreciated.
Thanks
Steve
This email and any attachments are intended solely for the use of the named recipients. If you are not the intended recipient you must not use, disclose, copy or distribute this email or any of its attachments and should notify the sender immediately and delete this email from your system. UK Research and Innovation (UKRI) has taken every reasonable precaution to minimise risk of this email or any attachments containing viruses or malware but the recipient should carry out its own virus and malware checks before opening the attachments. UKRI does not accept any liability for any losses or damages which the recipient may sustain due to presence of any viruses. Opinions, conclusions or other information in this message and attachments that are not related directly to UKRI business are solely those of the author and do not represent the views of UKRI.
- ADVimba camera timestamps Kinder, Steve (STFC,DL,TECH) via Tech-talk
RE: LabView-EPICS Integration using SoftIoc Akeroyd, Freddie (STFC, RAL, ISIS) via Tech-talk
<2020>
2025
device support for Keithley 428 Current Amplifier Sintschuk, Michael via Tech-talk
<2020>
2025
