Subject: ADEiger Status Parameters Polling
From: John Dobbins via Tech-talk <[email protected]>
Date: Thu, 5 Nov 2020 18:48:27 +0000
The ADEiger documentation reads:
"Status Parameters Polling
A few status parameters are read every time the ReadStatus PV is processed. A high rate polling causes issues, sometimes causing the detector to hang when, in conjunction, a parameter is set to an invalid value."
Can someone say what a "high rate" would be?  0.1 Hz, 1 Hz, 10 Hz? Other?
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: ADEiger Status Parameters Polling Bruno Martins via Tech-talk
Prev: Re: device support for Keithley 428 Current Amplifier Johnson, Andrew N. via Tech-talk
Next: GPIB remote control Mark Rivers via Tech-talk
Prev: caQtDM V4.3.0 Brands Helge (PSI) via Tech-talk
Next: Re: ADEiger Status Parameters Polling Bruno Martins via Tech-talk
