Subject: Stream device with waveform records
From: "Roehrig, Christian via Tech-talk" <[email protected]>
Date: Wed, 11 Nov 2020 17:45:12 +0000
Hello,
    I could use some help formatting an output from a waveform record that uses stream.
My IOC is built with:
    Base 7.0.4
    Asyn 4.40
    StreamDevice 2.8.8
    SNCSEQ 2.2.6
Here is the record definition.
record (waveform, "$(P)$(R):ScanListC")
   field(DESC, "Send configuration command.")
   field(DTYP, "stream")
   field(OUT,  "@daq970A.proto set_scan_route $(PORT)")
   field(NELM, "22")
   field(FTVL, "STRING")
Here is the stream protocol.
set_scan_route {
   separator=",";
   out "ROUT:SCAN(@%d)";
Here is the part of the SNL program that I use to put data into the waveform record.  It may put anywhere from 0 to NUM_CHANNELS (currently 22) integers into the waveform record.
int scan_list[NUM_CHANNELS];
assign scan_list to "{P}{R}:ScanListC.VAL";
ss set_scan {
   state construct_list {
      when (set_scan_list == 1) {
         set_scan_list = 0;
         counter = 0;
         for (channel = 0; channel < NUM_CHANNELS; channel++)
            pvGet(channel_include_in_scan_901A[channel]);
            if (channel_include_in_scan_901A[channel] == 1)
               scan_list[counter] = channel + 101;
               counter = counter + 1;
         pvPut(scan_list);
      } state construct_list
Here is the output on the asyn port when that part of the program runs after I have selected channels 101 and 103 on the MEDM screen and clicked the “Set Scan List” button.
ROUT:SCAN(@101,103,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0)
What I want the output to be is:
ROUT:SCAN(@101,103)
Is there a way to have stream reject the zeros that are not valid data?
Chris
Christian Roehrig
Principal Controls Engineer
Accelerator Systems Division
Argonne National Laboratory
Office: 630-252-7278
Cell: 630-327-6855
Re: Stream device with waveform records Johnson, Andrew N. via Tech-talk
Prev: Re: Connection to PVA server fails despite server Michael Davidsaver via Tech-talk
Next: Re: Stream device with waveform records Johnson, Andrew N. via Tech-talk
Prev: EPICS Integrator for Sweden TEL-EPC-201028 Jef Kong via Tech-talk
