Subject: Re: read RVB and VAL don't match when moving smarAct motors without encoders
From: "Peterson, Kevin M. via Tech-talk" <[email protected]>
To: "Reinhardt, Juliane" <[email protected]>
Cc: David Shapiro <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 13 Nov 2020 08:31:03 +0000
Juliane,
The MCS and MCS2 controllers have different command sets. That command won't work with the MCS controller.
Kevin
On Nov 13, 2020 1:45 AM, Juliane Reinhardt <[email protected]> wrote:
Hi Kevin,
smarAct does not support the EPICS driver, they did however mention the community-developed drivers that can be found on github. I had a look into this one: https://github.com/epics-motor/motorSmarAct/blob/master/smarActApp/src/smarActMCS2MotorDriver.cpp and found the variable theoryPosition that reads :CHAN%d:POS:TARG
Is that the required command to query a motor without an encoder? Then I could try to build a new IOC based on this package.
Juliane
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Juliane Reinhardt via Tech-talk
Next: Re: Connection to PVA server fails despite server Wlodek, Jakub via Tech-talk
Prev: Re: read RVB and VAL don't match when moving smarAct motors without encoders Kevin Peterson via Tech-talk
Next: New releases of ADGenICam and ADAravis Mark Rivers via Tech-talk
