1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Building StreamDevice with PCRE failing
From: "Wlodek, Jakub via Tech-talk" <tech-talk at aps.anl.gov>
To: "Reno, Ryan" <rreno at slac.stanford.edu>, "Manoussakis, Adamandios" <manoussakis1 at llnl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 17 Nov 2020 23:41:11 +0000
Hi Adam,
Did you try setting PCRE_LIB to  /usr/lib/x86_64-linux-gnu instead of /usr/lib, since you mentioned that is the exact location of the library?
Perhaps it will not find the library if it is in a nested directory.
Best,
Jakub
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Manoussakis, Adamandios via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, November 17, 2020 6:38 PM
To: Reno, Ryan <rreno at slac.stanford.edu>
Cc: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: RE: Building StreamDevice with PCRE failing
Hey Ryan,
Just an update but I wanted to test out where I thought it was looking for the libpcre.so.  So I copied the libpcre.so from /usr/lib over to myepics/base/lib/linux-x86_64/ and it was able to compile now (which is where the libpcre.a was).  This doesn’t seem like the correct way this should work as the RELEASE file should point towards the header and lib files which were in /usr/lib.  According to the documentation for streamdevice PCRE_LIB and PCRE_INCLUDE just needed to be set.  If anyone has an idea what might be wrong it would be greatly appreciated in just understanding why its looking in base/lib/linux-x86_64 and not the /usr/lib as defined in the RELEASE file of stream.
Adam
Sent: Tuesday, November 17, 2020 2:01 PM
To: Manoussakis, Adamandios <manoussakis1 at llnl.gov>
Hello,
It appears ld is trying to link the static libpcre.a archive file into a shared object which is causing the error.
This has happened to me in the past when there is only a static lib available in the linker search path. In other words, ld couldn’t find a shared object named libpcre and so it falls back to trying to link the static archive.
If this is indeed the cause of the problem for you then you have a few options. You’ll need to either provide a libpcre shared object to link in to your build, build libpcre statically with -fPIC, or configure your streamdevice build to be static only.
Hope this helps!
Best,
Ryan
From: Tech-talk <tech-talk-bounces at aps.anl.gov> On Behalf Of Manoussakis, Adamandios via Tech-talk
Sent: Tuesday, November 17, 2020 12:32 PM
To: tech-talk <tech-talk at aps.anl.gov>
Subject: Building StreamDevice with PCRE failing
Hello,
I have been trying to build streamdevice with PCRE but cannot for the life of me figure out why the compilation keeps failing (using libpcre and libpcre-dev). The release file for streamdevice has PCRE_LIB=/usr/lib  and PCRE_INCLUDE=/usr/include/pcre which seem to be pointing to the correct libraries.  I have looked into trying to build PCRE as a standalone epics module as well as stated in the documentation but ran into similar issues using PCRE v8 and v10 from the ftp(didn’t see v7 which is what the documentation originally built with for standalone).  It looks like one of the pcre shared objects is failing to compile and recommends to compile with -fPIC flag but it looks like that flag is already being used.  Couldn’t find a ton of info out on the internet with regards to this type of compilation error except that usually the -fPIC (position independent code) fixes it.  Below is my compilation error
/usr/bin/ranlib libstream.a
/usr/bin/g++ -o libstream.so -fPIC -shared -Wl,-hlibstream.so -L/home/jetson/myepics/support/asyn/lib/linux-x86_64 -L/home/jetson/myepics/support/stream/lib/linux-x86_64 -L/home/jetson/myepics/base/lib/linux-x86_64 -L/usr/lib -Wl,-rpath,/home/jetson/myepics/support/asyn/lib/linux-x86_64 -Wl,-rpath,/home/jetson/myepics/support/stream/lib/linux-x86_64 -Wl,-rpath,/home/jetson/myepics/base/lib/linux-x86_64 -Wl,-rpath,/usr/lib           -rdynamic -m64             DebugInterface.o DummyInterface.o AsynDriverInterface.o EnumConverter.o BCDConverter.o RawConverter.o RawFloatConverter.o BinaryConverter.o ChecksumConverter.o MantissaExponentConverter.o TimestampConverter.o RegexpConverter.o devaoStream.o devaiStream.o devboStream.o devbiStream.o devmbboStream.o devmbbiStream.o devmbboDirectStream.o devmbbiDirectStream.o devlongoutStream.o devlonginStream.o devstringoutStream.o devstringinStream.o devwaveformStream.o devaaiStream.o devaaoStream.o devcalcoutStream.o devlsiStream.o devlsoStream.o devscalcoutStream.o StreamVersion.o StreamBuffer.o StreamError.o StreamProtocol.o StreamFormatConverter.o StreamCore.o StreamBusInterface.o StreamEpics.o   -lasyn -ldbRecStd -ldbCore -lca -lCom  -lpcre -lpthread    -lm -lrt -ldl -lgcc
/usr/bin/ld: /home/jetson/myepics/base/lib/linux-x86_64/libpcre.a(libpcre_la-pcre_jit_compile.o): relocation R_X86_64_PC32 against symbol `pcre_callout' can not be used when making a shared object; recompile with -fPIC
/usr/bin/ld: final link failed: Bad value
collect2: error: ld returned 1 exit status
/home/jetson/myepics/base/configure/RULES_BUILD:288: recipe for target 'libstream.so' failed
make[2]: *** [libstream.so] Error 1
make[2]: Leaving directory '/home/jetson/myepics/support/stream/src/O.linux-x86_64'
/home/jetson/myepics/base/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/jetson/myepics/support/stream/src'
/home/jetson/myepics/base/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
RE: Building StreamDevice with PCRE failing Manoussakis, Adamandios via Tech-talk
RE: Building StreamDevice with PCRE failing Reno, Ryan via Tech-talk
Prev: RE: Building StreamDevice with PCRE failing Manoussakis, Adamandios via Tech-talk
Next: RE: Building StreamDevice with PCRE failing Manoussakis, Adamandios via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 17 Nov 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
