Regex replacement fixed it. I hadn't previously used that for outputs. Here's the change:
%01<sum8> becomes %01<sum8>%#/.*/\L0/
Garth
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Brown, Garth via Tech-talk <tech-talk at aps.anl.gov>
Sent: Tuesday, November 17, 2020 4:31 PM
To: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
Subject: streamdevice case sensitive sum8 checksum?
Is there a way to make checksums lower case?
I'm working on streamdevice support for the TE Technology TC-48-20 temperature controller. It uses the checksum that is coded as %01<sum8> in streamdevice format converter. If the checksum contains letters, they are upper case A-F. It works fine when the checksum
value only contains 0-9, but the controller rejects any checksum with A-F. I tried hard coding a checksum from a command it had rejected, but making the checksum value lower case, *5e00005A -> *5e00005a, and the controller accepted it. That's fine for requesting
values, but I can't hard code the checksum for setting values. Any ideas?
Garth
- streamdevice case sensitive sum8 checksum? Brown, Garth via Tech-talk
RE: Building StreamDevice with PCRE failing Manoussakis, Adamandios via Tech-talk
Re: EPICS Device Driver for YOKOGAWA WE500 vs WE400 Shuei YAMADA via Tech-talk
<2020>
2025
Heidenhain EIB 741 device Support Sintschuk, Michael via Tech-talk
<2020>
2025
ANJ, 20 Nov 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
