1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: Heidenhain EIB 741 device Support
From: Gillian Black via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Fri, 20 Nov 2020 19:46:48 +0000
Hi Michael.
We use the EIB741 boxes over TCP/IP at the Canadian Light Source.  Our driver works well but is incomplete; it handles EnDat 2.1 and 2.2 but not relative encoders.  However, there's a new project underway which may require that the driver be expanded.  What type of encoders are you using?  I believe there is also an issue switching encoders from IK320 directly to the EIB boxes, but I don't know if there is a similar problem going from IK342.
The driver is in two parts, one supplied by Heidenhain, and the one written at here at the CLS.  So our driver isn't speaking directly to the device, it's speaking to the Heidenhain software that comes with the boxes.
Please let us know if you'd like more information, and I will bring my colleague into the discussion.
Gillian Black
Control Systems Analyst
Saskatoon, Sask.
Canada
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Sintschuk, Michael via Tech-talk <tech-talk at aps.anl.gov>
Sent: November 18, 2020 10:04 AM
To: tech-talk at aps.anl.gov
Subject: External: Heidenhain EIB 741 device Support
Hello Epics community,
is someone using an EIB 741 (or 742) from Heidenhain for reading encoder signals with EPICS via TCP/IP communication? We want to exchange our old IK342 (also Heidenhain, VME-bus communication).
If not: can someone point me to a similar device Support that reads encoder signals (probably it will be streamDevice) from that I can derive support for the EIB741?
The EIB741 user manual can be found here.
Thanks in advance!
Michael
Michael Sintschuk
Bundesanstalt für Materialforschung und –prüfung (BAM)
8.5 Mikro-ZfP
Unter den Eichen 87
12205 Berlin
GERMANY
P: +49 30 8104-5736 (BESSY, Adlershof)
P: +49 30 8104-4065 (BAM, Steglitz)
michael.sintschuk at bam.de
Heidenhain EIB 741 device Support Sintschuk, Michael via Tech-talk
Prev: Re: phoebus forwarding macros Kasemir, Kay via Tech-talk
Next: calcout record, CP link, Cached Puts Hu, Yong via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Heidenhain EIB 741 device Support Sintschuk, Michael via Tech-talk
Next: phoebus forwarding macros Pierrick M Hanlet via Tech-talk
ANJ, 20 Nov 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
