Hi Henrique,
I looked through your repository. The db and proto files are well organized. One question for you: suppose I want to use the Lecroy Wavepro Scope to capture injection beam signal. Obviously, I need to use an external timing signal (which
is synchronized with beam injection) to trigger the Scope. Have you tried your StreamDevice driver to test this kind of triggered/synchronized data acquisition?
I guess Andrew’s application is APS-U filling pattern monitoring which requires high-speed (GS/s) digitizers / oscilloscopes. We have similar applications at NSLS-II and we are looking for alternatives to replace the discontinued compactPCI
Acqiris digitizers. The Lecroy WavePro 404HD seems amazing in terms of sampling rate and vertical resolution. If your StreamDevice driver can work with an external trigger, acquire 1,000,000 data points and update at 2Hz, we will definitely buy one WavePro
to give a try.
Thank you for sharing your code and experience!
Yong Hu
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Reply-To: Henrique Silva <henrique.silva at ess.eu>
Date: Friday, November 27, 2020 at 3:31 AM
To: "Johnson, Andrew N." <anj at anl.gov>, "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Subject: Re: Supported 'Scopes?
Probably a bit too late on this response, but if it helps, I've been working on the automation of a Lecroy Wavepro 404HD, which should be compatible with the 245HD as well.
The code is in this repository (still not documented at all):
https://gitlab.esss.lu.se/beam-diagnostics/bde/modules/wavepro
Cheers,
Henrique Silva
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Johnson, Andrew N. via Tech-talk <tech-talk at aps.anl.gov>
Sent: 20 October 2020 22:55:11
To: EPICS tech-talk
Subject: Supported 'Scopes?
I’ve been given a list of possible ’scopes to select for an APS Upgrade application, does anyone have experience using any of these with EPICS and can provide device support for one (hopefully as a StreamDevice protocol file and database):
Keysight DSO204A
Keysight DSOS054A
Teledyne/LeCroy Wavepro 245HD
Complexity comes for free, simplicity you have to work for.
- Supported 'Scopes? Johnson, Andrew N. via Tech-talk
- Re: Supported 'Scopes? Henrique Silva via Tech-talk
How do I pass a macro to a CSS Phoebus screen at startup from the command line Pietryla, Tony via Tech-talk
Re: How do I pass a macro to a CSS Phoebus screen at startup from the command line Kasemir, Kay via Tech-talk
<2020>
2025
Wireshark pvAccess plugin 秦天 via Tech-talk <tech-talk at aps.anl.go
<2020>
2025
ANJ, 01 Dec 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
