On Fri, 11 Dec 2020 at 10:51, Thomas Kutz via Tech-talk <tech-talk at aps.anl.gov> wrote:
Here are some pointers... Note that pvDatabase is a distinct context and ecosystem, and has not a lot of overlap with the classical EPICS IOC and its process database. If you want to use the EPICS process database (with all the hardware devices it supports), but create structured data that combines data from your EPICS database into a pvAccess structure, have a look at QSRV. [1] If you want to put a pvAccess server (serving out structured data) on top of your existing C++ application, have a look at PVXS. [2] If you want to see a tutorial for the pvDatabase library, have a look at the pvDatabase tutorial. [3] Cheers, ~Ralph
ANJ, 11 Dec 2020 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
