1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: ioc startup files not installed to INSTALL_LOCATION
From: Felix Krämer via Tech-talk <tech-talk at aps.anl.gov>
To: tech-talk at aps.anl.gov
Date: Mon, 14 Dec 2020 17:22:53 +0100
Hi all,
Currently, I do some contractor work for Gemini for a new Application
Development Environment based on RPM.
In this context, I am working on one part of it to provide a framework
for softIOC installation, everything readily set up with conserver
configuration, procServ etc. after installing a respective softIOC RPM.
I do this development work based on a makeBaseApp.pl generated softIOC
example from the EPICS Application Developer's Guide (
https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/GettingStarted.html#x3-60002.2
). For installing EPICS software using RPM we have to _relocate_
installed binaries, scripts etc. This works well, principally, but
regarding the example softIOC there do arise a few questions:
(1) The startup file under iocBoot (st.cmd) is not installed anywhere.
If INSTALL_LOCATION is not redefined, then this is not a problem, but if
I want to keep the sources distinct from the product, this seems not to
be consequent. I changed the Makefile from
TOP = ../..
include $(TOP)/configure/CONFIG
ARCH = $(EPICS_HOST_ARCH)
TARGETS = envPaths
include $(TOP)/configure/RULES.ioc
to
TOP = ../..
TARGETS = envPaths
SCRIPTS_IOC_Linux += st.cmd
to install the st.cmd to the binary install dir, at least. Additionally,
I set IOCS_APPL_TOP in CONFIG_SITE to the install location to let
envPaths look right. This works so far. Is this the way to go?
In this context it might also be an idea to create a new template
directory for makeBaseApp.pl and point to it using the -T option. I'd
rather use the EPICS original ones, though, to have no adaption work
with future versions.
(2) Another option I thought about would be to define a User Created
File type
https://epics.anl.gov/base/R3-15/6-docs/AppDevGuide/BuildFacility.html#x5-1570004.6.35
), e.g. a FILE_TYPE IOCBOOT which would install this st.cmd to a
INSTALL_IOCBOOT = $(INSTALL_LOCATION)/iocBoot/.... directory, for
example. But same here: it's sort of 'proprietary' to do things like
these and such special solutions might be incompatible with future
versions of EPICS.
Or do I think completely in the wrong direction and there is already a
mechanism  in place which to install the startup files to
INSTALL_LOCATION which I simply do not see?
Any help or ideas as well as confirmation appreciated.
Felix
Re: ioc startup files not installed to INSTALL_LOCATION Matt Rippa via Tech-talk
ioc startup file installation Felix Krämer via Tech-talk
Prev: Re: A tribute to our benefactors, errata bob dalesio via Tech-talk
Next: Re: A tribute to our benefactors Paul Sichta via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: ioc startup file installation Felix Krämer via Tech-talk
Next: Re: ioc startup files not installed to INSTALL_LOCATION Matt Rippa via Tech-talk
ANJ, 14 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
