Subject: RE: Timestamping Confusion
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 14 Dec 2020 21:32:09 +0000
Thank you both for the insight, it seems best for us to go a similar path of using TSEL to copy the timestamp from the digitizer to each of our waveform records and using TSE set to -2 to stop the IOC from overwriting the time field (please correct me if I am wrong on this). I think I just need to understand the best way to get the first timestamp and then use TSEL to pass it along to the other records.
Ralph when you stated to have the digitizer send the timestamp with the data, would I just have my digitizer set the TIME field in the waveform record then?
From: Tech-talk <[email protected]> On Behalf Of Ralph Lange via Tech-talk
Sent: Saturday, December 12, 2020 5:25 AM
To: EPICS Tech Talk <[email protected]>
Subject: Re: Timestamping Confusion
On Fri, 11 Dec 2020 at 22:33, Manoussakis, Adamandios via Tech-talk <[email protected]> wrote:
Thanks for the comments Michael, when you are dealing with hundreds of waveform records and the timestamps are being taken when each record is processed (I would assume these would all be off by some delay if multiple softIOCs are running) do you then just have a master time waveform to lineup all your other signals to t0?  It seems the digitizer would have a time stamp of t0 for all of its signals but the epics records would not all align at the same timestamp since each one isn't processed at t0 to be timestamped.
The EPICS Device Support needs to know the timestamp t0 (preferably sent with the data by the digitizer) and write it to each record's timestamp when it updates the record.
In that case, by configuring their TSE to -2, all waveform records can use the digitizer timestamp. That timestamp can even be forwarded (using TSEL) through post-processing chains, so that processed data may still use the timestamp that the digitizer sent with the raw data at the beginning of the chain.
Cheers,
~Ralph
RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Re: Timestamping Confusion Michael Davidsaver via Tech-talk
Re: Timestamping Confusion Ralph Lange via Tech-talk
Prev: Re: ioc startup files not installed to INSTALL_LOCATION Matt Rippa via Tech-talk
Next: Help Erika Jones via Tech-talk
Prev: Re: Timestamping Confusion Ralph Lange via Tech-talk
Next: RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
