Subject: Intended use of NTMultiChannel
From: "Paduan Donadio, Marcio via Tech-talk" <[email protected]>
Date: Thu, 17 Dec 2020 05:11:31 +0000
I have a NTMultiChannel created using the C++ API. I pvput to channelName passing a valid PV name. I placed a printf inside the process() method just to check if the record is processing and I can confirm it does.
When I pvget I expected to see the other fields of the record populated with values from the PV in channelName. Is it intended that inside process() I write the commands to bring the data for each channel and write to the fields of the NTMultiChannel? Is there a default “record support” that has it already implemented and I can use?
Some data:
Epics base 7.0.3
$ pvget GMDTest:NTScalar
GMDTest:NTScalar 0
$ pvput GMDTest:NTMultiChannel 'channelName=["GMDTest:NTScalar"]'
Old : epics:nt/NTMultiChannel:1.0
    any[] value
    string[] channelName []
    int[] severity []
    int[] status []
    string[] message []
    boolean[] isConnected []
New : epics:nt/NTMultiChannel:1.0
    any[] value
    string[] channelName ["GMDTest:NTScalar"]
    int[] severity []
    int[] status []
    string[] message []
$ pvget GMDTest:NTMultiChannel
GMDTest:NTMultiChannel epics:nt/NTMultiChannel:1.0
    any[] value
    int[] severity []
    int[] status []
    string[] message []
Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
Prev: RE: [EXTERNAL] RE: Timestamping Confusion Manoussakis, Adamandios via Tech-talk
Next: synApps_6_1 build error on windows-x64 with EPICS 7 Markus Huber via Tech-talk
Prev: WITec alpha300R VIS Heinz Junkes via Tech-talk
Next: Re: Intended use of NTMultiChannel Michael Davidsaver via Tech-talk
