Subject: Splitting a string in a protocol file
From: "Wang, Andrew via Tech-talk" <[email protected]>
Date: Thu, 17 Dec 2020 19:47:12 +0000
I’m relatively new to EPICS and I have been tasked with writing drivers for a Keysight oscilloscope. One of the commands that I need to set up is the following:
:CHANnel<N>:SCALe
This command requires a channel number and a value. So if I wanted to set the vertical scale of Channel 2 to 50 V, I would do
:CHANnel2:SCALe 50
I would like to work on both my protocol file and database file, but I am not sure how to go about it. This is what I currently have.
record(aao, "set_vert_scale")
              field(DESC, "Set vertical scale for a channel")
              field(DTYP, "stream")
              field(FTVL, "STRING")
              field(OUT, "@keysightOsc.proto setVertScale $(PORT)")
setVertScale
              separator = “,”
              out "%s:SCALe ";
My goal is for the user to enter a command such as caput set_vert_scale CHAN1,5 so that the string can be split in a manner such that CHAN1 and 5 can be concatenated to the beginning and end of :SCALe.
Any thoughts on how to do so?
Andy
Re: Splitting a string in a protocol file Johnson, Andrew N. via Tech-talk
Re: Splitting a string in a protocol file Michael Davidsaver via Tech-talk
Prev: FW: synApps_6_1 build error on windows-x64 with EPICS 7 Mark Rivers via Tech-talk
Next: Re: Splitting a string in a protocol file Johnson, Andrew N. via Tech-talk
