1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: Re: puzzle running softIocPVA
From: Rolf Keitel via Tech-talk <tech-talk at aps.anl.gov>
To: Michael Davidsaver <mdavidsaver at gmail.com>, "Johnson, Andrew N." <anj at anl.gov>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Sun, 20 Dec 2020 11:35:12 -0800
Title: signature text
Thanks Michael,
I had tried the -D option as I saw it when I did   softIocPVA -h.
It worked if I start the softIocPVA from the command line, but it did not work in the #!  line of st.cmd.
I did not know that it works without the white space, but just tried and it does. One always learns.
I was foreseeing problems for the IOC boot configuration system at TRIUMF as our system is based on each IOC having a boot directory, which contains all the files for the current configuration, including the IOC image and dbd file(s), so that no special tools are necessary for reverting back to a previous configuration.
As long as the -D option works in st.cmd (with or without white space) we will be ok.
- rolf -
On 2020-12-20 11:26 a.m., Michael Davidsaver wrote:
On 12/20/20 11:12 AM, Johnson, Andrew N. wrote:
IIRC the original softIoc had an option to specify the DBD file path on the command line (-D perhaps), and I don’t think Michael removed that so you might be able to get it to work by adding that option, possibly to your st.cmd’s #! line.
'-D' is recognized in 7.0.4.1, I didn't mention this since
#!./softIoc -D softIoc.dbd
won't work.
However, maybe you knew that
#!./softIoc -DsoftIoc.dbd
is recognized?  I hadn't until now.
Rolf Keitel, Ph.D.
Researcher Emeritus
TRIUMF, 4004 Wesbrook Mall
Vancouver, BC, V6T 2A3
Office: 604 222 7453
Home: 604 228 0594
e-mail: rolf at triumf.ca
Re: puzzle running softIocPVA Michael Davidsaver via Tech-talk
Re: puzzle running softIocPVA Johnson, Andrew N. via Tech-talk
puzzle running softIocPVA Rolf Keitel via Tech-talk
Prev: Re: puzzle running softIocPVA Michael Davidsaver via Tech-talk
Next: Re: puzzle running softIocPVA Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
ANJ, 20 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
