1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Subject: 回复: 回复: Reading multiple parameters from an incoming message.
From: "Li, Ji via Tech-talk" <tech-talk at aps.anl.gov>
To: "Hu, Yong" <yhu at bnl.gov>, Mark Rivers <rivers at cars.uchicago.edu>
Cc: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Wed, 30 Dec 2020 15:50:14 +0000
Hi Yong,
$(P){$(Q)-Ax:A}:RATE:RBV will scan automatically. Since I'm still testing and don't want the IOC shell be flooded by messages, SCAN has not been defined yet. It will be added later.
$(P){$(Q)-Ax:A}:STATUS and $(P){$(Q)-Ax:B}:STATUS are defined in another .db:
record(mbbi, "$(P){$(Q)-Ax:$(AX)}:STATUS") {
  field(DESC, "Pump Status")
  field(ZRVL, "0")
  field(ZRST, "Idle")
  field(ONVL, "1")
  field(ONST, "Infusing")
  field(TWVL, "2")
  field(TWST, "Withdrawing")
  field(THVL, "3")
  field(THST, "Stalled")
  field(FRVL, "4")
  field(FRST, "Target Reached")
  field(FVVL, "5")
  field(FVST, "Unknown")
I didn't use Maximize Severity Attribute.
Best,
-Ji Li
发件人: Hu, Yong <yhu at bnl.gov>
发送时间: 2020年12月30日 10:09
收件人: Li, Ji <liji at bnl.gov>; Mark Rivers <rivers at cars.uchicago.edu>
抄送: tech-talk at aps.anl.gov <tech-talk at aps.anl.gov>
主题: Re: 回复: Reading multiple parameters from an incoming message.
Ji,
Since I do not see the SCAN field in your .db, I do not see how $(P){$(Q)-Ax:A}:RATE:RBV gets processed. Is it linked by another record?
Also, I do not see how $(P){$(Q)-Ax:A}:STATUS and $(P){$(Q)-Ax:B}:STATUS are constructed in your .db. Are there any database links between all of these records? Do you use Maximize Severity Attribute (MS, MSS, or MSI) in your .db?
Yong
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Reply-To: "Li, Ji" <liji at bnl.gov>
Date: Thursday, December 24, 2020 at 6:36 PM
To: Mark Rivers <rivers at cars.uchicago.edu>
Subject:
Li, Ji 已与你共享 OneDrive for Business 文件。若要查看,请单击下面的链接。
Hi Mark,
I was referring to the PV for RATEA - $(P){$(Q)-Ax:A}:RATE:RBV.
Please see the attached files for the protocol, the database, the substitutions file, and the st.cmd. I only worked on Independent Condition to operate the two syringes separately. For better clarity I removed other protocols/databases definitions.
The .proto file contains the definition of this protocol and the referenced macro.
I have several .db files for different categories of information (rate/volume/time/...). The attached .db file defines the status PV - currently only RATEA. I expect implementation of other PVs that get values from this status message would be similar once I'm done with RATEA.
Best,
-Ji Li
发件人: Mark Rivers <rivers at cars.uchicago.edu>
发送时间: 20201224 14:53
主题: Re: Reading multiple parameters from an incoming message.
Hi Ji Li,
Can you send the rest of the database and protocol files, or at least the Status record and the $ax_status definition.
> The PV was showing INVALID(UDF_ALARM). Since the IOC didn't throw errors, I suppose the message was parsed correctly. How could this alarm have been caused?
Which PV are you referring to?
From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Li, Ji via Tech-talk <tech-talk at aps.anl.gov>
Sent: Thursday, December 24, 2020 11:04 AM
To: tech-talk at aps.anl.gov
Subject: Reading multiple parameters from an incoming message.
I'm working on an EPICS package for a Harvard Pump 33 DDS syringe pump using streamdevice protocols. I need to read several parameters from an incoming message that combines the status of two axes/syringes, which has the following format:
RATEA TIMEA VOLA STATUSA
RATEB TIMEB VOLB STATUSB
RATEA/B, TIMEA/B and VOLA/B are integers, and STATUSA/B are 6-character strings with each character indicating a specific status.
I'm trying to parse the message using multiple protocols and records. For RATEA, only grab the first integer:
Protocol:
getStatusRateAxA {
    out "status";
    in "%d %*d %*d %*c%*c%*c%*c%*c%*c\n%*d %*d %*d %*c%*c%*c%*c%*c%*c\n" $ax_status;
Record:
record(ai, "$(P){$(Q)-Ax:A}:RATE:RBV") {
  field(DESC, "Axis A rate readback")
  field(DTYP, "stream")
  field(INP, "@pump33dds.proto getStatusRateAxA($(P), $(Q), $(CMD)) $(PORT)")
  field(PREC, "0")
The .substitutions file referring to this record was loaded without errors. When I tried to retrieve status information, the IOC shell printed the following information without errors:
epics> 2020/12/24 11:29:06.797 /dev/ttyUSB0 write 8
status\r\n
2020/12/24 11:29:06.833 /dev/ttyUSB0 read 71
50000000000 0 22307784 w...I.\n83333333330 24723 2055394602192 i...I.\n::
"::" in the incoming message should be parsed by "$ax_status" in the protocol and it worked for other messages.
Best,
-Ji Li
Re: 回复: Reading multiple parameters from an incoming message. Hu, Yong via Tech-talk
Prev: 回复: Reading multiple parameters from an incoming message. Li, Ji via Tech-talk
Next: RE: Reading multiple parameters from an incoming message. Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025
Prev: Re: 回复: Reading multiple parameters from an incoming message. Hu, Yong via Tech-talk
ANJ, 30 Dec 2020 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
