1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: ClockTimeReport OS Clock Sync Not Running?
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Mon, 4 Jan 2021 20:42:24 +0000
Hey All,
Trying to understand how the timestamp is being placed in a record by looking at the ClockTimeReport and the generalTimeReport.  I also have been exploring using our NTP server with the IOC by setting the env variable EPICS_TS_NTP_INET to the NTP IP.  I may be understanding the reports incorrectly but wanted to make sure that without the NTP server at least the IOCs are syncing with the OS (my iocs are running from within a VM).  I do have the VM setup to sync with the OS.
How I understand it if no NTP server is around the IOC will grab its timestamp based off the IOC Boot server (OS Clock?).  But the ClockTimeReport is showing
epics> ClockTime_Report
Program started at 2021-01-04 12:22:24.937270
OS Clock synchronization thread not running.
But the generalTimeReport seems to match my OS clock
epics> generalTimeReport
Backwards time errors prevented 0 times.
Current Time Providers:
    "OS Clock", priority = 999
                Current Time is 2021-01-04 12:24:51.784595.
Event Time Providers:
                No Providers registered.
Re: ClockTimeReport OS Clock Sync Not Running? Johnson, Andrew N. via Tech-talk
Prev: Re: Question about the font name for EDM Lauritsen, Torben via Tech-talk
Next: Re: ClockTimeReport OS Clock Sync Not Running? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
