1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: can't readable 'arduino.proto' in 'helloWorldIOCApp/Db'
To: Andrea Solano <[email protected]>
Date: Mon, 11 Jan 2021 13:38:07 +0000
Hi Andrea,
You should always focus on the first error first.
> < envPaths
> Can't open envPaths: No such file or directory
That means that envPaths was not created for you when it should be.  The problem is like to be that you need to change your iocBoot/iocXXX/Makefile to set ARCH=linux-arm.  Then when you run "make" in that directory it will create envPaths for you.  iocXXX is whatever you have named your IOC boot directory.
From: Tech-talk <[email protected]> on behalf of Andrea Solano via Tech-talk <[email protected]>
Sent: Monday, January 11, 2021 5:42 AM
To: [email protected]
Subject: can't readable 'arduino.proto' in 'helloWorldIOCApp/Db'
Hi, I have a problem with reading the
protocol file. All code from: http://www.smolloy.com/2015/12/epics-serial-communication-with-arduino/
I use EPICS LAST VERSION
WITH ASYN AND STREAM DEVICE
LAST VERSION
Detail of mi ioc initialization:
#!../../bin/linux-arm/helloWorldIOC
< envPaths
epicsEnvSet(STREAM_PROTOCOL_PATH,"helloWorldIOCApp/Db")
macLib: macro TOP is undefined (expanding string cd "${TOP}")
dbLoadDatabase "dbd/helloWorldIOC.dbd"
helloWorldIOC_registerRecordDeviceDriver pdbbase
drvAsynSerialPortConfigure("SERIALPORT","/dev/ttyACM0",0,0,0)
asynSetOption("SERIALPORT",-1,"baud","115200")
asynSetOption("SERIALPORT",-1,"bits","8")
asynSetOption("SERIALPORT",-1,"parity","none")
asynSetOption("SERIALPORT",-1,"stop","1")
asynSetOption("SERIALPORT",-1,"clocal","Y")
asynSetOption("SERIALPORT",-1,"crtscts","N")
dbLoadRecords("db/arduino.db","PORT='SERIALPORT'")
## Load record instances
#dbLoadRecords("db/xxx.db","user=pi")
cd "/home/pi/EPICS/helloWorldIOC/iocBoot/iochelloWorldIOC"
iocInit
Starting iocInit
## EPICS R7.0.4.2-DEV
## Rev. R7.0.4.1-117-g4f14e9e674cfc16be1b2
2021/01/11 12:16:34.315589 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db'
2021/01/11 12:16:34.315919 _main_ while reading protocol 'set_digital' for 'led:set'
2021/01/11 12:16:34.316084 _main_ led:set: Protocol parse error
2021/01/11 12:16:34.316252 _main_ led:set: Record initialization failed
Error (514,11) PV: led:set ao: init_record
2021/01/11 12:16:34.316618 _main_ Can't find readable file 'arduino.proto' in 'helloWorldIOCApp/Db'
2021/01/11 12:16:34.316787 _main_ while reading protocol 'get_analog' for 'photo:get'
2021/01/11 12:16:34.316946 _main_ photo:get: Protocol parse error
2021/01/11 12:16:34.317103 _main_ photo:get: Record initialization failed
## Start any sequence programs
#seq sncxxx,"user=pi"
My protocol file:
Terminator = LF;
get_analog {
    out "R";
    in "R %f";
    ExtraInput = Ignore;
set_digital {
    out "W%d\n";
My db file:
record(ao, led:set) {
    field(DESC, "Arduino digi pin 11")
    field(DTYP, "stream")
    field(OUT, "@arduino.proto set_digital() $(PORT)")
    field(DRVL, "0")
    field(DRVH, "255")
record(ai, photo:get) {
    field(DESC, "Photo diode's output")
    field(INP, "@arduino.proto get_analog() $(PORT)")
    field(SCAN, ".5 second")
can't readable 'arduino.proto' in 'helloWorldIOCApp/Db' Andrea Solano via Tech-talk
Prev: can't readable 'arduino.proto' in 'helloWorldIOCApp/Db' Andrea Solano via Tech-talk
Next: Re: Can't enable custom frame rates for a basler camera in area detector Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: DBE_PROPERTY in CS-Studio Phoebus Roehrig, Christian via Tech-talk
