1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Interfacing HP3458A DMM using LinuxGPIB.
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Mark Rivers <[email protected]>, Kuldeep Joshi <[email protected]>, "Wang, SuYin Grass" <[email protected]>
Date: Fri, 22 Jan 2021 10:05:06 -0800
On 1/22/21 7:39 AM, Mark Rivers via Tech-talk wrote:
> Note that the documentation for devGpib (https://epics-modules.github.io/master/asyn/R4-41/devGpib.html) contains this at the top:
> NOTE: devGpib is obsolete and should not be used for new applications. StreamDevice<http://epics.web.psi.ch/software/streamdevice> should be used instead.
> I would suggesting converting the support to StreamDevice if you plan to do any significant development.
Something basic I did for a test stand at ALS awhile back which might serve as an example.
https://github.com/mdavidsaver/dmm_hp3458a
https://github.com/mdavidsaver/dmm_hp3458a/blob/master/iocBoot/ioctest/st.cmd
https://github.com/mdavidsaver/dmm_hp3458a/blob/master/dmmApp/Db/hp3458a.db
https://github.com/mdavidsaver/dmm_hp3458a/blob/master/dmmApp/protocol/hp3458a.proto
Interfacing HP3458A DMM using LinuxGPIB. Kuldeep Joshi via Tech-talk
Re: Interfacing HP3458A DMM using LinuxGPIB. Wang, SuYin Grass via Tech-talk
Re: Interfacing HP3458A DMM using LinuxGPIB. Mark Rivers via Tech-talk
Prev: Re: Strange CAS error Johnson, Andrew N. via Tech-talk
Next: Re: Strange CAS error Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Interfacing HP3458A DMM using LinuxGPIB. Mark Rivers via Tech-talk
Next: enabling pvaccess Randall Cayford via Tech-talk
