1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Channel connection performance
From: Axel Terfloth via Tech-talk <[email protected]>
To: [email protected]
Date: Mon, 25 Jan 2021 20:00:32 +0100
Hello,
i’m new to EPICS and take a closer look at it for evaluation purpose. To obtain a better understanding I started to dig deeper by implementing some tests which are based on the C++ examples. From a functional point of view everything I tried works nicely so far. Also the performance is generally very good in most of my test scenarios. Nevertheless one issue i came across is the time required for connecting to a channel  via PVA. In this scenario I set up 4000 process variables and implement one client which implements high frequency put and get access to a quarter (1000) of these proces variables. On my machine (which runs all processes for now) if takes about 250ms for a single channel connection. Once all channels are connected is really fast. Nevertheless connecting 1000 pvs takes more than 6 minutes. I currently connect channel by channel using the PvaClient API in my tests. Is there a more efficient way to connect to a large set of channels?  I would appreciate any hint.
Best regards,
Axel Terfloth
Re: Channel connection performance Marty Kraimer via Tech-talk
Re: Channel connection performance Michael Davidsaver via Tech-talk
Prev: setcap and nosuid Michael Davidsaver via Tech-talk
Next: Re: Channel connection performance Marty Kraimer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: setcap and nosuid Michael Davidsaver via Tech-talk
