1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: changing unit string to scale factor
From: Randall Cayford via Tech-talk <[email protected]>
To: "Engbretson, Mark S. via Tech-talk" <[email protected]>
Date: Mon, 25 Jan 2021 12:16:24 -0800
I have a device which returns a value and a string indicating the units of the value.  I’ll get inputs like 0.3nA or 3.4mA, etc.  Since I want to report the value in a consistent unit, I want to convert the unit string to a scale factor (nA=1, uA=1000, mA=10000) and then use a calc record to scale the value.   CALC records seem to only take numbers as input and I don’t see any other appropriate record type.
In programming I would use a case statement or if-elseif constructs.  How do I do this with EPICS record processing?
Randall
LBNL
RE: changing unit string to scale factor Mark Rivers via Tech-talk
Re: changing unit string to scale factor Zimoch Dirk (PSI) via Tech-talk
Prev: Altering timestamp of softIOC PV Reimer, Paul E. via Tech-talk
Next: Re: Channel connection performance Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Altering timestamp of softIOC PV Johnson, Andrew N. via Tech-talk
Next: RE: changing unit string to scale factor Mark Rivers via Tech-talk
