1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS Archiver routing issue
From: Jeong Han Lee via Tech-talk <[email protected]>
To: "Manoussakis, Adamandios" <[email protected]>
Date: Tue, 26 Jan 2021 22:41:42 -0800
  Sorry for the late reply, I added three EPICS environment variables
within configuration files, now three variables are defined in
archappl.conf. It is in the epics_env branch, and I will merge them
after Action returns "green". At this moment, I haven't tested it with
the real environment yet.  If anyone can do this, please let me know.
  Best,
  Han
On Tue, Jan 26, 2021 at 7:37 PM Manoussakis, Adamandios via Tech-talk
<[email protected]> wrote:
> Just wanted to say thanks to everyone for their ideas.  Finally tracked down the culprit.  For some reason the archiver wants all of its own environment variables (Preferences in Java), I had left out the EPICS_CA_MAX_ARRAY_BYTES and it was rejecting archiving the PVs because it was erroring out (wish I could find that error more easily in any of the logfiles).  Someone had mentioned the issue between the C libs vs the Java app that is the archiver and I finally added the max array variable to the archappl.conf file and it started to work.  CSStudio seems to take variables from the env variables of the host and I have not had an issue with not declaring the max array bytes in its settings.ini file.
> SOLUTION:
> EPICS_CA_MAX_ARRAY_BYTES must be defined in the archappl.conf file along with the EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR if you are using them.  I would guess along with any other env variables that you need the archiver to know about.
> From: Hu, Yong <[email protected]>
> Sent: Tuesday, January 26, 2021 11:24 AM
> To: Manoussakis, Adamandios <[email protected]>; [email protected]
> Hi Adam,
> Different subnets. I remember I have to use double quotes “” (and spaces inside “”) for the IP list if you pay close attention to the lines below. Also, do not forget to restart the Archiver Appliance (AA) after changed are made on archappl.conf.
> Other suggestions you may try:
> On the Epics Archiver Computer (192.168.10.20), type “cainfo PVName”. You should see something like this: Host: 192.168.11.21:5064;
> On the Epics Archiver Computer (192.168.10.20), type “traceroute 192.168.11.21”, “sudo netstat -nr” to see the gateway/router settings;
> Check AA log files, i.e. search PVName in log files;
> The last thing you could try is to use Wireshark (with Channel Access filter/plugin) on both 192.168.10.20 and 192.168.11.21 to see what is going on when you click the “Archive” button to archive a new PV from AA web interface.
> Good luck!
> Yong
> From: Tech-talk <[email protected]> on behalf of "[email protected]" <[email protected]>
> Reply-To: "Manoussakis, Adamandios" <[email protected]>
> Date: Tuesday, January 26, 2021 at 1:05 PM
> To: "[email protected]" <[email protected]>
> Subject: RE: EPICS Archiver routing issue
> Hi Yong,
> Are you going across different subnets in your setup? Or is the archiver on the same subnet as the IOCs you are reading PVs from?  I did have success when they were on the same subnet.
> Sent: Tuesday, January 26, 2021 7:25 AM
> To: Manoussakis, Adamandios <[email protected]>; Abdalla Ahmad <[email protected]>; [email protected]
> I also used Han’s scripts for installation of Archiver Appliance. And it works for me after adding these lines in archappl.conf and restarting the AA after changes are made on archappl.conf:
> EPICS_CA_AUTO_ADDR_LIST=YES
> EPICS_CA_ADDR_LIST="localhost 10.0.142.197"
> Date: Tuesday, January 26, 2021 at 2:19 AM
> To: Abdalla Ahmad <[email protected]>, "[email protected]" <[email protected]>
> At least according to the documentation it made it sound like setting AUTO=YES just created a list of local ips then anything in the ADDR_LIST would just be appended on.  But will have to see if maybe the archiver is doing something weird.
> From: Abdalla Ahmad <[email protected]>
> Sent: Monday, January 25, 2021 11:17 PM
> In our case, setting it to YES will default CA traffic to the local subnet and would not go across VLANs (ignoring the address list) rendering the archiver not seeing any PV. But something I am not sure of is that which one overrides the other.
> Best Regards,
> Abdalla.
> From: Manoussakis, Adamandios <[email protected]>
> Sent: Tuesday, January 26, 2021 9:12 AM
> To: Abdalla Ahmad <[email protected]>; [email protected]
> That seems odd, I thought CSStudio and the catools (caget,camonitor etc) were the same as what the archiver was using.  I will try setting the AUTO_ADDR_LIST=NO, I assumed this was just helpful in general since it would do an introspection of network and didn’t think it would do any harm (What might be the issue of running this with YES?).  Currently I have the EPICS_CA_ADDR_LIST set in ~/.profile as well to the ip of the host running the IOC.
> Sent: Monday, January 25, 2021 11:05 PM
> Hello Adam
> I think CSS is using different CA implementation other than the archiver, maybe that’s why some configs won’t work. Try set the address list in the archiver (and in ~/.bashrc) to the IP of the host running the IOC and if there are multiple IOCs configure the network manager as in the article I sent. Also you can try setting EPICS_CA_AUTO_ADDR_LIST=NO in the archiver and see if it helps.
> Best Regards,
> Abdalla
> Sent: Tuesday, January 26, 2021 9:00 AM
> Hey Abdalla,
> Currently I set the EPICS_CA_ADDR_LIST in the archappl.conf (using Hans site specific install currently) and wondering if I need to set it to the gateway or to the ip of the host running the IOC (Usually I just set it to the IP of the host running the IOC)?  But at the moment I only have one IOC running on that host anyways.
> I just don’t understand why the CS Studio (which is on one VLAN) and CAGET are able to grab the PV data from the IOC that is on the other VLAN but the Archiver is not getting through.  I am starting to wonder if the archappl.conf is not reading the EPICS_CA_ADDR_LIST properly?
> Thanks,
> Adam
> Sent: Monday, January 25, 2021 10:32 PM
> Hello Adamandios
> It depends on how the VLANs and subnets are configured. We have the archiver on a separate VLAN from the IOCs VLAN (both VLANs are not isolated from each other), but the archiver can see and archive all PVs from all the IOCs through:
> Setting EPICS_CA_ADDR_LIST variable set in the sampleStartup.sh script.
> Configuring the NetworkManager dispatcher if you have multiple IOCs on the same host: https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host
> For CSS, since the IOCs and the clients are on the same subnet, we don’t set any EPICS variables, except if we want some PVs from other VLANs like beamlines which are requested through EPICS CA gateway, here we set the EPICS_CA_ADDR_LIST to the IP of the gateway.
> Best Regards,
> Abdalla.
> From: Tech-talk <[email protected]> On Behalf Of Manoussakis, Adamandios via Tech-talk
> Sent: Tuesday, January 26, 2021 2:56 AM
> To: EPICS tech-talk <[email protected]>
> Subject: EPICS Archiver routing issue
> Hello All,
> I think I am having problems with routing with the epics archiver.  When I have the archiver on a LAN and is on the same subnet as the IOCs being archived it seems to work fine but when I have archiver on a different subnet it doesn’t seem to want to archive those PVs anymore. For example
> Same Subnet, CS Studio Picks up PVs, caget works, archiver works
> 192.168.10.20 Epics Archiver Computer
> 192.168.10.21 IOC running
> Different Subnet, CS Studio picks up PVs, caget works, Archiver will not archive PVs
> 192.168.11.21 IOC running
> I have both the epics variables set in my env variables, in archappl.conf (archiver file), in settings.ini (cs studio file).  It seems odd that caget, cs studio work fine but the archiver is having an issue seeing the IOC that is on the other subnet.  Is there another environment variable I am missing that needs to be set when services are on different subnets like this?  I checked firewalls/ports/traffic it seems like the same requests are being made by cs studio/caget as the archiver but the archiver ones don’t seem to go anywhere (just keep trying to retransmit).
> EPICS_CA_ADDR_LIST=192.168.11.21
RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
RE: EPICS Archiver routing issue Abdalla Ahmad via Tech-talk
Re: EPICS Archiver routing issue Hu, Yong via Tech-talk
Prev: RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
Next: phoebus DataBrowser - ArchiverAppliance data retrieval through SSL-only reverse-proxy Thomas Birke via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: EPICS Archiver routing issue Manoussakis, Adamandios via Tech-talk
