1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Phoebus Strip tool and Databrowser Only Show Latest Point
From: "Smith, William via Tech-talk" <[email protected]>
Date: Wed, 3 Feb 2021 16:44:58 +0000
I have a fresh install of Phoebus from: https://controlssoftware.sns.ornl.gov/css_phoebus/nightly/phoebus-linux.zip
I am running Ubuntu 20.04. I have installed Java with:
sudo apt update
sudo apt install openjdk-14-jdk
When I run Phoebus I can run the striptool and databrowser examples without problem. When I try and add a PV to a striptool/databrowser which I can monitor without issue with the text-update widget/ probe, the strip tool only displays the most recent point, it doesn't have any history and when a new value comes in it just plots that. It ends up looking like a flat line across the whole plot that moves up and down with the value of the PV. I have tried with different PV's some from ai records, others from longin, all the same. My colleagues don't have this problem with their installations done in the same way. Any ideas what might be causing the problem?
All the best,
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Bernd Rech (Sprecher), Prof. Dr. Jan Lüning, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Re: Phoebus Strip tool and Databrowser Only Show Latest Point Kasemir, Kay via Tech-talk
Prev: AW: combining long strings Sintschuk, Michael via Tech-talk
Next: Re: Phoebus Strip tool and Databrowser Only Show Latest Point Kasemir, Kay via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Base 3.16.1.0 Mark Rivers via Tech-talk
