1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Estimate Data Rate and BW requirements
To: "Manoussakis, Adamandios" <[email protected]>
Date: Tue, 9 Feb 2021 21:39:15 +0000
I think the bandwidth requirements depend almost entirely on the number of large arrays you will be sending via Channel Access.  If you use areaDetector and Channel Access to transport arrays from an IOC to a client viewer you can easily consume 100% of GigE bandwidth.  If you have a display with 1000 scaler PVs each changing at 10Hz that will only be 80kB/s (plus overhead), so it is less than 0.1% of GigE bandwidth.
From: Tech-talk <[email protected]> on behalf of Manoussakis, Adamandios via Tech-talk <[email protected]>
Sent: Tuesday, February 9, 2021 3:04 PM
To: [email protected]
Subject: Estimate Data Rate and BW requirements
Hello All,
Trying to understand a few things on data rate and bandwidth with regards to epics.  Most of epics is based off UDP/TCP, so I was thinking that your max will be related to TCP throughput calculations?
Is there a rule of thumb for epics on estimating BW requirements?
If the infrastructure is there to transmit and no BW issues what is the upper limit for data rate given a number of PVs?
Is there an upper limit depending on PVs and there sizes when doing transfers like caget?
Thanks
RE: Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
Prev: Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
Next: Question about option MaxPermSize for CSS lzf neu via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Estimate Data Rate and BW requirements Manoussakis, Adamandios via Tech-talk
