1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: ASYN Module: Workaround for bug due to improper handling of signal in linux-gpib
From: Kuldeep Joshi via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 10 Feb 2021 08:05:43 +0000
Hello,
Can the workaround as suggested in this link https://sourceforge.net/p/linux-gpib/bugs/50/#85e8
be incorporated for the drvLinuxGpib.c in the ASYN module.
The workaround suggests to mask all the signals during call to ibrd() or ibwrt()
Thanks and regards,
Kuldeep
The text of the above link is reproduced as below
"When a program receives a signal while it is in a call to a linux-gpib driver it can happen that the application hangs. This is because for historic reasons the linux-gpib driver framework does not properly handle the return of -ERESTARTSYS from its device drivers. Unfortunately to fix this systematically in the package is a lot of work. The symptoms of a hang, due to signals, are that the program receiving the signal hangs, blocking other programs from accessing the device and in the console log you can find messages such
as:
agilent_82350b: write wait interrupted.
or
.../gpib/ni_usb/ni_usb_gpib.c: ni_usb_nonblocking_receive_bulk_msg: interrupted
Re: ASYN Module: Workaround for bug due to improper handling of signal in linux-gpib Mark Rivers via Tech-talk
Prev: Question about option MaxPermSize for CSS lzf neu via Tech-talk
Next: Re: Question about option MaxPermSize for CSS Jeong Han Lee via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Question about option MaxPermSize for CSS Jeong Han Lee via Tech-talk
Next: Re: ASYN Module: Workaround for bug due to improper handling of signal in linux-gpib Mark Rivers via Tech-talk
