1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: EPICS Archiver Appliance: Fatal error when deploying the WARs (probably Java)
From: Markus Huber via Tech-talk <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Wed, 10 Feb 2021 12:44:39 +0100
Dear EPICS community,
i am trying to get the EPICS Archiver Appliance running.
I have successfully tested the Archiver Appliance in the "Quickstart"
mode. After that i have installed it and started up the tomcats. During
startup there occur some fatal exceptions (Java).
It would be great if someone has an idea how to solve this:
= Description =
* I followed the installation instructions descibed on
[https://slacmshankar.github.io/epicsarchiver_docs/installguide.html]
under the sections "Using an install script", "Details", and the
following sections.
* The installation and the creation of the four tomcat containers went
fine (without error).
* When i start the tomcats using a customized startup.sh, the servers
start up, but the deployment of the war files failes due to a fatal
error in each tomcat instance.
* The error-causing exceptions on the four tomcats are the following
(the full outputs are in the last section of this mail):
** engine/logs/catalina.err        Caused by:
java.lang.ClassNotFoundException: org.apache.log4j.Logger
** etl/logs/catalina.err              Caused by:
java.util.zip.ZipException: zip END header not found
** mgmt/logs/catalina.err        Caused by: java.util.zip.ZipException:
** retrieval/logs/catalina.err    Caused by: java.util.zip.ZipException:
* When i had run the Archiver Appliance before without installation but
in the "Quickstart" mode i could successfully archive PVs on the same
system.
= Questions =
* It looks like a Java problem, so am i doing something wrong regarding
my Java setup (see section System Specification below)?
* Am i using incompatible versions of Java and MariaDB (see section
= System Specification =
== OS and Architecture ==
> lsb_release -a
No LSB modules are available.
Distributor ID:    Ubuntu
Description:    Ubuntu 20.04.2 LTS
Release:    20.04
Codename:    focal
> uname -a
Linux E335 5.4.0-65-generic #73-Ubuntu SMP Mon Jan 18 17:25:17 UTC 2021
x86_64 x86_64 x86_64 GNU/Linux
== Java ==
> java -version
openjdk version "14.0.2" 2020-07-14
OpenJDK Runtime Environment (build 14.0.2+12-Ubuntu-120.04)
OpenJDK 64-Bit Server VM (build 14.0.2+12-Ubuntu-120.04, mixed mode,
sharing)
> echo $JAVA_HOME
/usr/lib/jvm/java-14-openjdk-amd64
> sudo update-alternatives --config java
Es gibt 3 Auswahlmöglichkeiten für die Alternative java (welche
/usr/bin/java bereitstellen).
  Auswahl      Pfad Priorität Status
* 0            /usr/lib/jvm/java-14-openjdk-amd64/bin/java 1411
automatischer Modus
  1            /usr/lib/jvm/java-11-openjdk-amd64/bin/java 1111
manueller Modus
  2            /usr/lib/jvm/java-14-openjdk-amd64/bin/java 1411
manueller Modus
  3            /usr/lib/jvm/java-8-openjdk-amd64/jre/bin/java 1081
manueller Modus
== MySQL ==
> mysql --version
mysql  Ver 15.1 Distrib 10.3.25-MariaDB, for debian-linux-gnu (x86_64)
using readline 5.2
Within $TOMCAT_HOME/lib i have mysql-connector-java-8.0.22.jar.
== Tomcat ==
apache-tomcat-9.0.43
= The full output of each catalina.err =
engine/log/catalina.err:
OpenJDK 64-Bit Server VM warning: Ignoring option MaxPermSize; support
was removed in 8.0
Feb. 10, 2021 10:47:57 AM
org.apache.catalina.startup.VersionLoggerListener log
INFORMATION: Server Version:        Apache Tomcat/9.0.43
Feb. 10, 2021 10:47:58 AM
INFORMATION: Server built:          Jan 28 2021 20:25:45 UTC
INFORMATION: Server version number: 9.0.43.0
INFORMATION: OS Name:               Linux
INFORMATION: OS Version:            5.4.0-65-generic
INFORMATION: Architektur:           amd64
INFORMATION: Java Home: /usr/lib/jvm/java-14-openjdk-amd64
INFORMATION: JVM Version:           14.0.2+12-Ubuntu-120.04
INFORMATION: JVM Hersteller:        Private Build
INFORMATION: CATALINA_BASE:
/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine
INFORMATION: CATALINA_HOME:
/home/markus/EPICS-archiver-appliance/tomcat/apache-tomcat-9.0.43
INFORMATION: Command line argument: -XX:MaxPermSize=128M
INFORMATION: Command line argument: -XX:+UseG1GC
INFORMATION: Command line argument: -Xmx4G
INFORMATION: Command line argument: -Xms4G
INFORMATION: Command line argument: -ea
-Dcatalina.base=/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine
-Dcatalina.home=/home/markus/EPICS-archiver-appliance/tomcat/apache-tomcat-9.0.43
INFORMATION: Command line argument: -Dcommons.daemon.process.id=3187
INFORMATION: Command line argument: -Dcommons.daemon.process.parent=3186
INFORMATION: Command line argument: -Dcommons.daemon.version=1.2.4
INFORMATION: Command line argument: abort
Feb. 10, 2021 10:47:58 AM org.apache.catalina.core.AprLifecycleListener
lifecycleEvent
INFORMATION: The Apache Tomcat Native library which allows using OpenSSL
was not found on the java.library.path:
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/engine/WEB-INF/lib/native/linux-x86_64::/usr/lib/jvm/java-14-openjdk-amd64/lib/server:/usr/lib/jvm/java-14-openjdk-amd64/lib:/usr/java/packages/lib:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib]
Feb. 10, 2021 10:48:09 AM org.apache.coyote.AbstractProtocol init
INFORMATION: Initialisiere ProtocolHandler["http-nio-17666"]
Feb. 10, 2021 10:48:10 AM org.apache.catalina.startup.Catalina load
INFORMATION: Server initialization in [18104] milliseconds
Feb. 10, 2021 10:48:11 AM org.apache.catalina.core.StandardService
startInternal
INFORMATION: Starting service [Catalina]
Feb. 10, 2021 10:48:11 AM org.apache.catalina.core.StandardEngine
startInternal
INFORMATION: Starting Servlet engine: [Apache Tomcat/9.0.43]
Feb. 10, 2021 10:48:11 AM org.apache.catalina.startup.HostConfig deployWAR
INFORMATION: Deploying web application archive
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/engine.war]
Feb. 10, 2021 10:48:26 AM org.apache.catalina.startup.HostConfig deployWAR
SCHWERWIEGEND: Fehler beim deployen des Web-Applikationsarchivs
java.lang.IllegalStateException: Error starting child
    at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:720)
    at
org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:690)
    at
org.apache.catalina.core.StandardHost.addChild(StandardHost.java:706)
    at
org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:946)
    at
org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1792)
    at
java.base/java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:515)
    at java.base/java.util.concurrent.FutureTask.run(FutureTask.java:264)
    at
org.apache.tomcat.util.threads.InlineExecutorService.execute(InlineExecutorService.java:75)
    at
java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:118)
    at
org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:757)
    at
org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:426)
    at org.apache.catalina.startup.HostConfig.start(HostConfig.java:1520)
    at
org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java:309)
    at
org.apache.catalina.util.LifecycleBase.fireLifecycleEvent(LifecycleBase.java:123)
    at
org.apache.catalina.util.LifecycleBase.setStateInternal(LifecycleBase.java:423)
    at
org.apache.catalina.util.LifecycleBase.setState(LifecycleBase.java:366)
    at
org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:936)
    at
org.apache.catalina.core.StandardHost.startInternal(StandardHost.java:843)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183)
    at
org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1384)
    at
org.apache.catalina.core.ContainerBase$StartChild.call(ContainerBase.java:1374)
    at
    at
java.base/java.util.concurrent.AbstractExecutorService.submit(AbstractExecutorService.java:140)
    at
org.apache.catalina.core.ContainerBase.startInternal(ContainerBase.java:909)
    at
org.apache.catalina.core.StandardEngine.startInternal(StandardEngine.java:262)
    at
org.apache.catalina.core.StandardService.startInternal(StandardService.java:434)
    at
org.apache.catalina.core.StandardServer.startInternal(StandardServer.java:930)
    at org.apache.catalina.startup.Catalina.start(Catalina.java:772)
    at
java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native
Method)
    at
java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
    at
java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
    at java.base/java.lang.reflect.Method.invoke(Method.java:564)
    at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:342)
    at
Method)
    at
    at
    at
org.apache.commons.daemon.support.DaemonLoader.start(DaemonLoader.java:241)
Caused by: org.apache.catalina.LifecycleException: Failed to start
component
[StandardEngine[Catalina].StandardHost[localhost].StandardContext[/engine]]
    at
org.apache.catalina.util.LifecycleBase.handleSubClassException(LifecycleBase.java:440)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:198)
    at
org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:717)
    ... 41 more
Caused by: java.lang.NoClassDefFoundError: Lorg/apache/log4j/Logger;
    at java.base/java.lang.Class.getDeclaredFields0(Native Method)
    at java.base/java.lang.Class.privateGetDeclaredFields(Class.java:3139)
    at java.base/java.lang.Class.getDeclaredFields(Class.java:2262)
    at
org.apache.catalina.util.Introspection.getDeclaredFields(Introspection.java:104)
    at
org.apache.catalina.startup.WebAnnotationSet.loadFieldsAnnotation(WebAnnotationSet.java:269)
    at
org.apache.catalina.startup.WebAnnotationSet.loadApplicationListenerAnnotations(WebAnnotationSet.java:89)
    at
org.apache.catalina.startup.WebAnnotationSet.loadApplicationAnnotations(WebAnnotationSet.java:67)
    at
org.apache.catalina.startup.ContextConfig.applicationAnnotationsConfig(ContextConfig.java:332)
    at
org.apache.catalina.startup.ContextConfig.configureStart(ContextConfig.java:989)
    at
org.apache.catalina.startup.ContextConfig.lifecycleEvent(ContextConfig.java:303)
    at
    at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5082)
    ... 42 more
Caused by: java.lang.ClassNotFoundException: org.apache.log4j.Logger
    at
org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1364)
    at
org.apache.catalina.loader.WebappClassLoaderBase.loadClass(WebappClassLoaderBase.java:1187)
    ... 55 more
INFORMATION: Deployment of web application archive
has finished in [14.845] ms
deployDirectory
INFORMATION: Deploye Web-Applikations-Verzeichnis
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/manager]
Feb. 10, 2021 10:48:32 AM org.apache.tomcat.jdbc.pool.ConnectionPool
checkPoolConfiguration
WARNUNG: maxIdle is larger than maxActive, setting maxIdle to: 10
Loading class `com.mysql.jdbc.Driver'. This is deprecated. The new
driver class is `com.mysql.cj.jdbc.Driver'. The driver is automatically
registered via the SPI and manual loading of the driver class is
generally unnecessary.
Feb. 10, 2021 10:48:37 AM org.apache.jasper.servlet.TldScanner scanJars
INFORMATION: At least one JAR was scanned for TLDs yet contained no
TLDs. Enable debug logging for this logger for a complete list of JARs
that were scanned but no TLDs were found in them. Skipping unneeded JARs
during scanning can improve startup time and JSP compilation time.
Feb. 10, 2021 10:48:38 AM
org.apache.catalina.util.SessionIdGeneratorBase createSecureRandom
WARNUNG: Creation of SecureRandom instance for session ID generation
using [SHA1PRNG] took [117] milliseconds.
Feb. 10, 2021 10:48:39 AM org.apache.catalina.startup.HostConfig
deployDirectory
INFORMATION: Deployment of web application directory
has finished in [12.874] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/ui]
Feb. 10, 2021 10:48:44 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:45 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:45 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [6.138] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/examples]
Feb. 10, 2021 10:48:52 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:55 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:56 AM org.apache.catalina.core.ApplicationContext log
INFORMATION: ContextListener: contextInitialized()
INFORMATION: SessionListener: contextInitialized()
INFORMATION: ContextListener: attributeAdded('StockTicker',
'async.Stockticker@5908e6d6')
Feb. 10, 2021 10:48:56 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [11.193] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/host-manager]
Feb. 10, 2021 10:49:00 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:49:00 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:49:00 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [4.134] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/docs]
Feb. 10, 2021 10:49:05 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:49:05 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:49:05 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [4.469] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/ROOT]
Feb. 10, 2021 10:49:07 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:49:07 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:49:07 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [2.318] ms
Feb. 10, 2021 10:49:07 AM org.apache.coyote.AbstractProtocol start
INFORMATION: Starting ProtocolHandler ["http-nio-17666"]
Feb. 10, 2021 10:49:07 AM org.apache.catalina.startup.Catalina start
INFORMATION: Server startup in [57694] milliseconds
Feb. 10, 2021 11:32:02 AM org.apache.catalina.users.MemoryUserDatabase
backgroundProcess
INFORMATION: Reloading memory user database [UserDatabase] from updated
source
[file:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/conf/tomcat-users.xml]
etl/logs/catalina.err:
was removed in 8.0
/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl
-Dcatalina.base=/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl
INFORMATION: Command line argument: -Dcommons.daemon.process.id=3191
INFORMATION: Command line argument: -Dcommons.daemon.process.parent=3190
lifecycleEvent
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/engine/WEB-INF/lib/native/linux-x86_64::/usr/lib/jvm/java-14-openjdk-amd64/lib/server:/usr/lib/jvm/java-14-openjdk-amd64/lib:/usr/java/packages/lib:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib]
Feb. 10, 2021 10:48:08 AM org.apache.coyote.AbstractProtocol init
INFORMATION: Initialisiere ProtocolHandler["http-nio-17667"]
Feb. 10, 2021 10:48:09 AM org.apache.catalina.startup.Catalina load
INFORMATION: Server initialization in [17706] milliseconds
startInternal
startInternal
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/etl.war]
Feb. 10, 2021 10:48:13 AM org.apache.catalina.startup.HostConfig deployWAR
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
Method)
    at
    at
    at
Method)
    at
    at
    at
Caused by: org.apache.catalina.LifecycleException: Konnte Komponente
[org.apache.catalina.webresources.JarResourceSet@28194a50] nicht
initialisieren
    at
    at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:139)
    at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:173)
    at
org.apache.catalina.webresources.StandardRoot.startInternal(StandardRoot.java:726)
    at
org.apache.catalina.core.StandardContext.resourcesStart(StandardContext.java:4830)
    at
org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:4966)
    at
    ... 41 more
Caused by: java.lang.IllegalArgumentException: java.io.IOException:
java.lang.reflect.InvocationTargetException
    at
org.apache.catalina.webresources.AbstractSingleArchiveResourceSet.initInternal(AbstractSingleArchiveResourceSet.java:143)
    at org.apache.catalina.util.LifecycleBase.init(LifecycleBase.java:136)
    ... 48 more
Caused by: java.io.IOException: java.lang.reflect.InvocationTargetException
    at
org.apache.tomcat.util.compat.Jre9Compat.jarFileNewInstance(Jre9Compat.java:209)
    at
org.apache.tomcat.util.compat.JreCompat.jarFileNewInstance(JreCompat.java:226)
    at
org.apache.catalina.webresources.AbstractSingleArchiveResourceSet.initInternal(AbstractSingleArchiveResourceSet.java:140)
    ... 49 more
Caused by: java.lang.reflect.InvocationTargetException
    at
java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native
Method)
    at
java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
    at
java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
    at
java.base/java.lang.reflect.Constructor.newInstanceWithCaller(Constructor.java:500)
    at
java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:481)
    at
org.apache.tomcat.util.compat.Jre9Compat.jarFileNewInstance(Jre9Compat.java:206)
    ... 51 more
Caused by: java.util.zip.ZipException: zip END header not found
    at java.base/java.util.zip.ZipFile$Source.zerror(ZipFile.java:1502)
    at java.base/java.util.zip.ZipFile$Source.findEND(ZipFile.java:1397)
    at java.base/java.util.zip.ZipFile$Source.initCEN(ZipFile.java:1404)
    at java.base/java.util.zip.ZipFile$Source.<init>(ZipFile.java:1209)
    at java.base/java.util.zip.ZipFile$Source.get(ZipFile.java:1172)
    at
java.base/java.util.zip.ZipFile$CleanableResource.<init>(ZipFile.java:717)
    at java.base/java.util.zip.ZipFile.<init>(ZipFile.java:237)
    at java.base/java.util.zip.ZipFile.<init>(ZipFile.java:167)
    at java.base/java.util.jar.JarFile.<init>(JarFile.java:347)
    ... 57 more
has finished in [2.584] ms
Feb. 10, 2021 10:48:14 AM org.apache.catalina.startup.HostConfig
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/manager]
Feb. 10, 2021 10:48:24 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:30 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:31 AM
using [SHA1PRNG] took [138] milliseconds.
Feb. 10, 2021 10:48:31 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [17.875] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/ui]
Feb. 10, 2021 10:48:36 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:36 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:37 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [5.315] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/examples]
Feb. 10, 2021 10:48:45 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:48 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:49 AM org.apache.catalina.core.ApplicationContext log
'async.Stockticker@57bd6a8f')
Feb. 10, 2021 10:48:49 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [12.164] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/host-manager]
Feb. 10, 2021 10:48:54 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:54 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:55 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [5.664] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/docs]
Feb. 10, 2021 10:48:58 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:48:58 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:48:59 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [3.931] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/ROOT]
Feb. 10, 2021 10:49:02 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:49:02 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:49:02 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [3.811] ms
Feb. 10, 2021 10:49:02 AM org.apache.coyote.AbstractProtocol start
INFORMATION: Starting ProtocolHandler ["http-nio-17667"]
Feb. 10, 2021 10:49:03 AM org.apache.catalina.startup.Catalina start
INFORMATION: Server startup in [53602] milliseconds
mgmt/logs/catalina.err:
was removed in 8.0
-Dcatalina.base=/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt
INFORMATION: Command line argument: -Dcommons.daemon.process.id=3182
INFORMATION: Command line argument: -Dcommons.daemon.process.parent=3179
lifecycleEvent
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/engine/WEB-INF/lib/native/linux-x86_64::/usr/lib/jvm/java-14-openjdk-amd64/lib/server:/usr/lib/jvm/java-14-openjdk-amd64/lib:/usr/java/packages/lib:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib]
INFORMATION: Initialisiere ProtocolHandler["http-nio-17665"]
INFORMATION: Server initialization in [18272] milliseconds
startInternal
startInternal
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/mgmt.war]
Feb. 10, 2021 10:48:14 AM org.apache.catalina.startup.HostConfig deployWAR
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
Method)
    at
    at
    at
Method)
    at
    at
    at
[org.apache.catalina.webresources.JarResourceSet@1a5b6f42] nicht
initialisieren
    at
    at
    at
    at
    at
    ... 41 more
    at
    ... 48 more
    at
    at
    at
    ... 49 more
    at
Method)
    at
    at
    at
    at
    at
    ... 51 more
    at
    ... 57 more
has finished in [2.519] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/manager]
Feb. 10, 2021 10:48:25 AM org.apache.tomcat.jdbc.pool.ConnectionPool
using [SHA1PRNG] took [162] milliseconds.
deployDirectory
has finished in [17.605] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/ui]
deployDirectory
has finished in [5.544] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/examples]
'async.Stockticker@517704')
deployDirectory
has finished in [11.784] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/host-manager]
Feb. 10, 2021 10:48:54 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [5.622] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/install]
Feb. 10, 2021 10:48:59 AM org.apache.jasper.servlet.TldScanner scanJars
deployDirectory
has finished in [4.269] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/docs]
deployDirectory
has finished in [3.700] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/ROOT]
Feb. 10, 2021 10:49:06 AM org.apache.tomcat.jdbc.pool.ConnectionPool
Feb. 10, 2021 10:49:06 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:49:06 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [3.598] ms
Feb. 10, 2021 10:49:06 AM org.apache.coyote.AbstractProtocol start
INFORMATION: Starting ProtocolHandler ["http-nio-17665"]
Feb. 10, 2021 10:49:06 AM org.apache.catalina.startup.Catalina start
INFORMATION: Server startup in [56270] milliseconds
retrieval/logs/catalina.err:
was removed in 8.0
/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval
-Dcatalina.base=/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval
INFORMATION: Command line argument: -Dcommons.daemon.process.id=3195
INFORMATION: Command line argument: -Dcommons.daemon.process.parent=3194
lifecycleEvent
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/etl/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/engine/webapps/engine/WEB-INF/lib/native/linux-x86_64:/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/mgmt/webapps/engine/WEB-INF/lib/native/linux-x86_64::/usr/lib/jvm/java-14-openjdk-amd64/lib/server:/usr/lib/jvm/java-14-openjdk-amd64/lib:/usr/java/packages/lib:/usr/lib/x86_64-linux-gnu/jni:/lib/x86_64-linux-gnu:/usr/lib/x86_64-linux-gnu:/usr/lib/jni:/lib:/usr/lib]
INFORMATION: Initialisiere ProtocolHandler["http-nio-17668"]
INFORMATION: Server initialization in [17713] milliseconds
Feb. 10, 2021 10:48:10 AM org.apache.catalina.core.StandardService
startInternal
Feb. 10, 2021 10:48:10 AM org.apache.catalina.core.StandardEngine
startInternal
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/retrieval.war]
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
    at
Method)
    at
    at
    at
Method)
    at
    at
    at
initialisieren
    at
    at
    at
    at
    at
    ... 41 more
    at
    ... 48 more
    at
    at
    at
    ... 49 more
    at
Method)
    at
    at
    at
    at
    at
    ... 51 more
    at
    ... 57 more
has finished in [2.194] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/manager]
using [SHA1PRNG] took [130] milliseconds.
deployDirectory
has finished in [18.303] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/ui]
deployDirectory
has finished in [5.488] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/examples]
deployDirectory
has finished in [12.006] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/host-manager]
deployDirectory
has finished in [6.149] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/docs]
Feb. 10, 2021 10:48:59 AM org.apache.tomcat.jdbc.pool.ConnectionPool
deployDirectory
has finished in [3.791] ms
deployDirectory
[/home/markus/EPICS-archiver-appliance/single_machine_install/tomcats/retrieval/webapps/ROOT]
Feb. 10, 2021 10:49:03 AM org.apache.jasper.servlet.TldScanner scanJars
Feb. 10, 2021 10:49:03 AM org.apache.catalina.startup.HostConfig
deployDirectory
has finished in [3.726] ms
Feb. 10, 2021 10:49:03 AM org.apache.coyote.AbstractProtocol start
INFORMATION: Starting ProtocolHandler ["http-nio-17668"]
INFORMATION: Server startup in [53691] milliseconds
Thank you and kind regards
Markus Huber
TU Munich, CoSES Reseach Center
Prev: RE: Firmware upgrade for MRF event generators and receivers Abdalla Ahmad via Tech-talk
Next: Re: ASYN Module: Workaround for bug due to improper handling of signal in linux-gpib Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: ASYN Module: Workaround for bug due to improper handling of signal in linux-gpib Mark Rivers via Tech-talk
Next: Re: EPICS Archiver Appliance: Fatal error when deploying the WARs (probably Java) Shankar, Murali via Tech-talk
