Was the .1 machine running more than one IOC? If so, then this could be the problem. Using the IP address of the .1 machine in the EPICS_CA_ADDR_LIST on .2 will only work for the first IOC started on .1. It will not be able to find the second IOC. This is because the second IOC needs to use a different port for Channel Access.
Almost. When using an explicit IP for the name search, only the last IOC started on that machine will answer. See this how-to page for a discussion and possible fixes. The second IOC does not need to use a different port.
Cheers, ~Ralph
- Re: Identical Process Variable names on Multiple Servers Michael Davidsaver via Tech-talk
- Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
- Re: Identical Process Variable names on Multiple Servers Mark Rivers via Tech-talk
- RE: Identical Process Variable names on Multiple Servers Manoussakis, Adamandios via Tech-talk
Job opportunity at FRIB Konrad, Martin via Tech-talk
<2021>
2025
<2021>
2025
ANJ, 18 Feb 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
IRMIS
Talk
Documents
Links
Licensing
